The Camo Beast as it Evolves.
Old Nov 15, 2014 | 03:08 AM
  #161
corbo1962's Avatar
corbo1962
I decided to put a couple of LED light bars on top of the roll bar and take off the PIA's. I fabricated the mount
Here it is installed
Old Nov 15, 2014 | 10:29 AM
  #162
Holy smokes, that's a lotta lites. Had a chance to try it out yet? Would love to see pics from the cab, at night.
Also, is your camo painted that way?
Old Nov 15, 2014 | 05:47 PM
  #163
Johnn123's Avatar
Johnn123
Oh man thats gonna be stupid bright! Looks great man!
Old Nov 16, 2014 | 05:30 AM
  #164
corbo1962's Avatar
corbo1962
Haven't tried them out yet, but that will be happening shortly after the steering box issue is straightened out. Maybe Tuesday night I'll get it out for a night run and take some pictures. The camo is painted, I did it last year while the truck was down waiting on the axles.
Thanks, down here in the south west, some of the best wheelin is at night and there is no such thing as too much light.
Old Nov 16, 2014 | 11:51 AM
  #165
You did a great job on the paint.
I suck at body work.
Old Nov 16, 2014 | 10:03 PM
  #166
Wh1t3NuKle's Avatar
Wh1t3NuKle
Nice work! Is the mount on the forward tube of the roll bar or the rear? If able to do on the rear, then you might be able to make the mount such that you can rotate back and down to clear anything? lol Oh wait...no trees out in Texas.
Bodylift got done?
Just odd about the steering stuff.
Old Nov 17, 2014 | 12:01 AM
  #167
Ham Bone's Avatar
Ham Bone
hey corbo. I need a paint job on my truck. Just want a fresh layer or two of that Deep patriot blue stuff lol
Arent you having issues with the redhead?
Just for reference. i bought a Mopar reman from the dealership for about 100 less than the redhead. and it is holding up nicely so far. we will see how it is this time next year. My origninal stock one lasted about 150k so thats good enough for me.
its also guaranteed to be 100% rebuilt. Not just new seals. price difference agrees with that.
good luck getting it sorted out.
Old Nov 17, 2014 | 04:16 AM
  #168
corbo1962's Avatar
corbo1962
Yes I have had some trouble with the redhead. My stock gear box made it to 170K, it failed after the axle swap, 37" tires and the ARB locker in the front. That Locker puts stress on the pitman arm bearing in the gear box. I guess my luck in getting a couple of bad ones. I'll install the new one with the Synergy support bracket tomorrow after I wake up. I get off work at 5am. I haven't given up on redhead yet. Thanks for the info on the mopar one. I'm thinkin if this new setup fails, then I'm gonna look into hydro assist.
Bodylift got done?
Thanks! When I built the roll bar, four straps were welded between the two tubes for the other lights. I attached the new light bar with four bolts to the four straps, so the bar is between the two 3" tubes.
The body lift is to happen soon. I'm thinking mid december. When I have sufficient time to make the bumpers. I've been getting all the materials rounded up for the bumpers and rock sliders. I'll start prefabbing as much of them as I can.
I don't quite understand why you haven't hade problems since your axle swap. You must have just got a good steering gear. I haven't been able to get one to last more than 4-6 months. The cheap cardone remans only made it a couple of months.
Old Nov 17, 2014 | 10:53 AM
  #169
Wh1t3NuKle's Avatar
Wh1t3NuKle
I encourage you to work the BL in first. Bumpers can still go on w/o issue if you need to drive around until starting to build the new ones. The rear one involves some lame hole redrilling. Have a step drill, but I'm sure you have that in your arsenal.
PM sent.
Old Nov 17, 2014 | 07:54 PM
  #170
corbo1962's Avatar
corbo1962
PM sent.
I will definitely put the BL on first, just want to get it all done shortly after.
I installed the new gear box and brace
This all that came with the brace
This give you an idea of how the thing goes
The brace was actually for a 3/4 to 1 ton and I guess the spacing on the frame was a little different so I had to mill out the hole so the hole on the brace would center over the pitman arm
Then got it put up and bolted on. This was actually a two man job but a PITA for one.
I think this should resolve the issues, I guess time will tell
