The Official 2014 2nd Gen RAM Forum OT thread
Old Jun 8, 2014 | 10:36 PM
  #451
Ham Bone's Avatar
Ham Bone
Originally Posted by jkeaton
I replaced pretty much every component on my Z28, compressor, evaporator, orifice, drier, etc. It had been open for a number of years before I bought it. I put al the new parts on, filled it with one can of oil and 2 cans of R134 without every having it vacuumed. Worked great. Blew cold air whenever I needed it. All depends on how much you want to spend.
I might just try this
Old Jun 9, 2014 | 12:58 AM
  #452
aofarrell2's Avatar
aofarrell2
I repeat, if you had it open and haven't had it vacuumed out since it was opened, if you charge it, you will have AIR, MOISTURE, and DIRT, no matter how clean and careful you were. Any of those will burn up your compressor and will contaminate the refrigerant. It is an absolute must to vacuum it out. Having the air in there could cause pressure differences and hotspots - and those could cause the cycling switches to operate improperly causing system damage. Bad idea.
Read this, especially the moisture, particulate/solids, and non-condensable gases sections.
http://www.hvacprimesource.com/Refrigerants.html
Old Jun 9, 2014 | 08:20 AM
  #453
Like I said, all depends on how much you want to spend. I know what I did is not best practice, but it worked (and is still working) for me.
Old Jun 9, 2014 | 11:56 AM
  #454
redneck_ram's Avatar
redneck_ram
well, i need to replace the head on the motor of the lawn tractor i just picked up. one of the rocker mounts is snapped from the casting. gonna get a used head, and new pushrods, and put it back together.
ill have under 150 into this tractor!
Old Jun 9, 2014 | 01:09 PM
  #455
aofarrell2's Avatar
aofarrell2
Make sure you set valve clearance. Valves love to snap in small engines. Take a feeler gage and put it between the pushrod and valve stem at TDC on compression stroke (both valves closed). If you have less than .004, need to add a little more clearance. More than .008 and that will hurt performance, generally .004-.006 is good unless specifically noted by the manufacturer otherwise. Also if you have the cam out, grind out the compression relief bumps on them (don't yell at me if you grind the wrong bump though!). They hurt performance. A good battery and starter will start it just fine without compression relief. Anytime you have the valves/seats ground, or put in new valvetrain components it is necessary to check valve clearance. If you have too little clearance, remove the valve and grind the tip of the valve stem down VERY slowly and evenly. Then clean it, put a couple drops of kerosene or engine oil on it, reassemble, and try again til you get the clearance correct.
Old Jun 9, 2014 | 01:16 PM
  #456
redneck_ram
This isnt my first rodeo young grasshopper. Ive been working on small engines for over a decade....
Old Jun 9, 2014 | 01:17 PM
  #457
aofarrell2's Avatar
aofarrell2
Sorry man... Just trying to help...
Gee whiz.
Old Jun 9, 2014 | 03:27 PM
  #458
redneck_ram
Gee whiz.
I know, but you gotta remember that you're probably the youngest on the forum....
Old Jun 9, 2014 | 04:28 PM
  #459
snowboundrmk's Avatar
snowboundrmk
I want to take the compression relief off my motorcycle.
Old Jun 9, 2014 | 05:06 PM
  #460
redneck_ram
turns out the lawn tractor is about 16 years old... doesnt look that old though. cant wait to get the motor back together, and hear it run!
