lift
Old Apr 26, 2014 | 08:45 AM
Nope. Go beyond that though, and all sorts of stuff will need to change.
Old Apr 26, 2014 | 10:20 AM
bulldodgemoe's Avatar
bulldodgemoe
good, thanks for all the info. with that i can save money and get some good tires. looking at 32"s
Old Apr 26, 2014 | 10:49 AM
Johnn123's Avatar
Johnn123
For 3", don't think control arms are necessary. Beyond that... yeah.
AFAIK, you need new lowers as it uncenters the axle just a wee bit, enough to cause to problems.
OP if you want to do it right stay away from blocks and spacers. Get lift springs and AAL's.
Old Apr 26, 2014 | 03:39 PM
BBartow's Avatar
BBartow
Lift Springs: http://www.topguncustomz.com/p-9441-...x#.U1wHsvldXC8
AALs: http://www.topguncustomz.com/p-8691-...x#.U1v_IfldXC8
Control Arms: http://www.summitracing.com/parts/sja-dll232
And I'm sure someone could link you an adjustable track bar.
Old Apr 26, 2014 | 06:27 PM
Johnn123's Avatar
Johnn123
Originally Posted by BBartow
This one would work well. http://www.summitracing.com/dom/part...iew/make/dodge
Old Apr 26, 2014 | 09:49 PM
bulldodgemoe
actually perfect!!! that is exactly what i will go with. i like that. thanks so much.
after lookign around for tires i have 265/70r17. they area already basicly 31" tires and i have plenty of room with these. so upping it to 35"s or 36"s will be no problem at all.
Old Apr 27, 2014 | 01:11 AM
BBartow's Avatar
BBartow
You aren't going to be able to fit 35s or 36s with just a 3" lift. You will have major rubbing. 33s would be perfect and you can get away with running stock gears with them.
Old Apr 27, 2014 | 01:28 AM
tincan57's Avatar
tincan57
BBartow ...Thank you for answering...........I bought & traded my trucks already lifted (so I did not feel qualified to state the answer as you have provided). I appreciate the work you've put in your rig. K.
Example - My tires on this 97 sig pic are 33" and I'm running with 3.54 gearing (ok). It has 2" leveling springs and a 3" body lift. If I were to run 35" tires then I would need to re-gear to at least 4.10's to save my auto tranny and engine from an early demise. There would be a clearance issue. K
Last edited by tincan57; Apr 27, 2014 at 02:04 PM. Reason: name/trade/bought diesel-example
Old Apr 27, 2014 | 08:53 AM
bulldodgemoe
oopps forgot to mention i am throwing a 2" body lift under her to. my current tires which as i mentioned are basicly 31" tires and i currently have plenty of room even with 17" rims.
but yea i agree with 35/36" it will be tight
Old May 4, 2014 | 02:42 PM
bulldodgemoe
crap!!! now i am thinking if i go 3" why not go 5"?? hmmm
