E-fan
Old May 14, 2014 | 07:05 PM
Spillage's Avatar
Spillage
I also noticed better A/C performance.
Old May 15, 2014 | 08:36 AM
Blue Mopar01's Avatar
Blue Mopar01
Thanks guys for the input. Is a JY fan from a jeep or taurus a pusher or puller fan? I'm guessing the angle of the blades judges if its a pusher or puller?
Old May 15, 2014 | 10:42 AM
You can make the fan do whatever you want. They are DC motors, so, they will spin either direction. If you mount it up, and it spins the wrong way, just reverse the polarity on the motor.
Old May 16, 2014 | 08:33 AM
Blue Mopar01
Oh, yeah that makes sense now.
Old May 16, 2014 | 09:39 PM
Hahns5.2's Avatar
Hahns5.2
Originally Posted by beeker
Why is the e-fan needed? I drove all winter last year without my clutch fan installed to see if it made a difference in power, and it made zero difference.
It's not going to make a power difference in the winter when the clutch isn't locked up. In the summer my fan sucked a huge amount of power, I'm glad it's gone.
Old May 17, 2014 | 10:27 AM
RDuck's Avatar
RDuck
Winter testing and summer testing is two different worlds.
Winter E fan allows faster warm up.
Summer E fan allows full fan flow cooling even with the engine idle.
Old May 17, 2014 | 11:28 AM
and for the off-roaders that do deep water, being able to turn OFF the fan, so it isn't tossing high-velocity water around the engine compartment is rather a nice feature as well.
Old May 18, 2014 | 10:31 AM
RDuck's Avatar
RDuck
Exactly why my mudders was On, Off, Automatic.
Plus nobody want to suck a fan through the radiator.
Old May 18, 2014 | 12:44 PM
that_guy's Avatar
that_guy
I've had the taurus fan setup for almost 2 years now and it's been great. I had a new depo fan first, but it quit a week after the warranty was up, so I got one from the junkyard and it's been fine since. The one you want is from a late 80s to early 90s 3.8L. Those are the dual speed ones that move the most air.
I've got a dakota digital controller for mine that turns it on depending on engine temp (monitored by a sensor in the upper hose) and the a/c state. It uses both the high and low speed. I've heard people saying good things about the flex a lite variable speed controllers too.
Not sure about the Ram's radiator, but it's a near perfect fit for my Durango's radiator. There's about an inch on the bottom that isn't covered by a shroud a about 2 inches on the top. I haven't seen the temp get above 195 or so even in 110+ humid weather sitting in traffic with the a/c on.
Old May 19, 2014 | 10:14 PM
Blue Mopar01
Thanks Guy for that info! I haven't been able to get to the JY yet, graduation is this weekend and we've been cleaning up for it. So I'll be set back a bit.
