Engine for Torque
Old Aug 15, 2015 | 11:35 PM
  #21
bargeman's Avatar
bargeman
Originally Posted by 1997JollyGreenGiant
Kegger mod will cause you to lose some torque. The more of the runners you remove, the more torque you lose.
Thanks got it. Leave the runners alone. I'll just open it up around the injector tips .
Old Aug 16, 2015 | 08:25 AM
  #22
Spillage's Avatar
Spillage
It's not that you loose torque, you move it up in the RPM range... this is fine for racers, but not for street and rock crawling.
Old Aug 16, 2015 | 12:10 PM
  #23
I did the kegger mod on my truck, and I rather like the results. Of course, I actually gained power across the RPM range, simply because of how badly my plenum was blown......
The 'mod' that made the MOST difference though, was the double roller timing chain. I did that separately from any other mods, so, it was the only change done..... and I was AMAZED at the difference it made. Of course, my engine had 170K+ miles at the time........
Old Aug 16, 2015 | 02:04 PM
  #24
Khris1994's Avatar
Khris1994
Default Engine for Torque
How would a new chain make a difference? Does it really stretch enough to kill timing?
Old Aug 16, 2015 | 02:12 PM
  #25
Mine was REALLY sloppy. I could pull the chain off the cam gear, without unbolting anything... Yes, it was THAT bad. That throws the whole system out of whack. Valve and ignition timing both get severely retarded. (as in: Late. Not stupid. )
Old Aug 18, 2015 | 07:32 AM
  #26
bargeman's Avatar
bargeman
Besides fixing the plenum plate what exactly did you mod on your kegger?
Old Aug 18, 2015 | 07:54 PM
  #27
Shortened the runners about 1.5 inches, and radiused the openings nicely. That, and cleaned out the accumulation of crap that was in it.... (I bought another intake for 25 bucks to mod, so all I had to do was swap 'em. I spent a lotta hours with a dremel, and sawzall on the intake......)
Old Aug 18, 2015 | 10:42 PM
  #28
redneck_ram's Avatar
redneck_ram
i have comp cams 20-745-9, along with HS 1.7s. thing was a torque monster when i had my long tubes.
.212/.218
.480/.480
lsa 114
with the 1.7s its becomes .510/.510
cant wait to get my dakota, and get some good long tubes, so i can have fun with the motor!
Old Sep 11, 2015 | 10:38 AM
  #29
cjantczak's Avatar
cjantczak
Holy wow!! Makes me wanna change the timing chain in my 5.9 now Lol! its got 211k, ive got all the paperwork from the previous owner and no where does it say that the chain was ever replaced, and he took really good care of the truck. correct me if im wrong but i thought i had read somewhere before the chain should be replaced every 60k? Like i said i could be wrong but i swear ive heard that before
Old Sep 11, 2015 | 10:58 AM
  #30
So far as I know, the chain isn't a maintenance item.... timing BELTS on the other hand.....
