To paint, wrap, or let it be....
I have the clear coat and paint fading on the hood and roof with a small rust repair on the passages rear wheel well. I have gotten several quotes ranging From 700 to 900 to repaint. I did see a local ad for wrapping service, did not get a quote yet.. Has anybody done this if so how much and did you like it after. Or should I just let it be (because it's a 18 year old truck) and drive it for as long as possible even thought it will be for a long time because it only has 68,000 on the ODO as it sits now.. What you guys think.... Forgot the repaint is just the hood and roof with the small rust repair not the whole truck.
Yea. The rust needs to be repaired that's a given, and I was thinking of spraying the roof black with a satin or gloss clear on the cheap myself. The hood I want to look really good and when it comes to paint the best I could pull off is adequate. So the roof is doable, but the hood needs a pro.. The wrap would have been a black or dark grey roof with same for hood or red (if a good match red) and fix the small rust spot and touch up paint myself... Just have not seen any Rams with a wrap.
