Trailer brake controller ?
Old Jun 22, 2014 | 01:09 PM
getdown78's Avatar
getdown78
Default Trailer brake controller ?
I have a tekonsha voyager that i hooked up to the factory plug in a 96 R1500 and it doesn't work ? Is there something special i need to do ?
Old Jun 22, 2014 | 04:35 PM
getdown78's Avatar
getdown78
Doesn't come on ? I need info please ?
Old Jun 22, 2014 | 06:33 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
is there a wire run to the trailer connector? if the truck did not come with trailer brakes the wire needs to be run from the controller to the trailer connector.
Old Jun 22, 2014 | 10:30 PM
redneck_ram's Avatar
redneck_ram
there are 2 fuses i believe under the hood in the pdc for it. check em out. otherwise, you have other issues...
just kidding, 1 fuse(40a), and 1 relay.
Old Jun 22, 2014 | 10:36 PM
redneck_ram
Old Jun 29, 2014 | 04:53 PM
getdown78's Avatar
getdown78
I have power and ground at the controller but no led light on it ? Does the trailer have to be plugged into the truck for it to come on ?
Old Jun 29, 2014 | 05:11 PM
Derick C.'s Avatar
Derick C.
It should. I also have a tekonsha controller and the trailer has to be plugged in before the controller comes on.
Old Jun 29, 2014 | 05:16 PM
Ham Bone's Avatar
Ham Bone
Yes has to be plugged in. I have a tek voyager xp. It turns on green when it has a good connection. Red when manually braking
Old Jun 29, 2014 | 06:18 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
yes the trailer needs to be connected lol
Old Jun 29, 2014 | 09:09 PM
redneck_ram
youre all correct, to an extent. i have a reese controller in my truck, and it will light up when i hit the brakes without a trailer connected. its just one small led dot, but it still lights up.
also, on my jeep, i have a tekonsha prodigy p2 and it will light up completely on start up, and if there is no trailer, it will blink nc for no connection, and then go on stand by mode.
trucks controller is wired to the factory brake adapter, jeep is hardwired to the battery, and spliced into the brake switch wire. then connected to the blue wire that feeds the trailer connector.
