Transmission Shifting Problems
Old Nov 6, 2015 | 05:15 PM
Demailman's Avatar
Demailman
Default Transmission Shifting Problems
I have a 1998 Dodge Ram 1500, 5.9l, 46re transmission. Recently my tranny went out and not having enough cash for a new one. I went to a salvage yard and pulled one there. I got it installed and it wouldn't up shift past second gear. So I replaced the governor pressure sensor and regulator. Now it will shift, but when it gets warmed up and you are driving, it suddenly acts like you put it in neutral. So I pulled it over, turned off the engine and restarted it. I put it in gear and it takes off like nothing is wrong. The problem is it continues to do this all the time. And I can not figure out what is going on.
Does anyone know what's going on? Thank you in advance.
Old Nov 7, 2015 | 11:13 AM
What year was the donor trans? What year truck did you get the sensor/solenoid for?
Old Nov 7, 2015 | 02:38 PM
Demailman's Avatar
Demailman
I got it out of a truck exactly like mine, same year paint and everything. I ordered the solenoids through Amazon ($89 for pair) for my truck. For a 96 through 99
Old Nov 7, 2015 | 04:54 PM
Need to know what pressures are doing when it drops out of gear. The PCM knows, and if you have a scanner, will tell you, but, will it tell you the TRUTH becomes the big question.
Wonder if your cheap sensors were exactly that......
Old Nov 8, 2015 | 01:21 AM
Demailman's Avatar
Demailman
I have a decent scanner. I'll take a look tomorrow and let you know. Thanks for your help
Old Nov 8, 2015 | 02:14 AM
Demailman's Avatar
Demailman
But I take it from what you have said. That the sensors can drop it out of gear. And it would seem to me that it is basically an electric problem since de-energizing the system and then starting again fixes the problem for a short time.
Old Nov 8, 2015 | 10:11 AM
If the pressure sensor is lying, the PCM may think pressure is good, when in reality, it is not. That will allow things to slip, or simply not engage at all.
Old Nov 8, 2015 | 10:46 AM
Demailman's Avatar
Demailman
Okay, now will the pcm have what you need in the memory or will I need to drive the truck and watch the scanner for the pressures when it drops out of gear
Old Nov 8, 2015 | 11:21 AM
Need to see what pressure is doing while it is acting up. (take note of what pressure is doing when it is working right, and compare the values.)
Old Nov 8, 2015 | 11:38 PM
Demailman's Avatar
Demailman
I will do that but I've never used my scanner for this type of thing. So I'm on a learning curve. Give me a little time and I for sure will figure it out and get back to you. I definitely need the help. Thanks
