Differential Covers
Old Nov 1, 2018 | 03:03 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Biggest thing with aftermarket covers are that they have the following: magnet to pick up metal shavings, fill hole and drain hole, and usually a place to put a temp sensor in. Now sure you could add all that (other then the magnet?) to the factory cover. But the average person doesn't have the know how.
Old Nov 3, 2018 | 09:09 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
See my earlier post. The aftermarket covers appear to be doing more harm than good.
Old Nov 3, 2018 | 02:52 PM
MoparFanatic21
I understand that and I watched the videos and agree. What I'm saying is if I just bought the truck and want to add a diff temp sensor. Sure I could pay a shop $85 (around here) to drill a hole tap it or weld a nut on the cover. Or I could spend $325 and get all of the above that was mentioned. I called a local shop and asked how much to install a temp sensor hole, fill hole, and add a magnet to my rear diff. $465 is what they quoted me. I can but an aftermarket cover for $200. I added all that to my rear diff for less then $40. But the average Joe can't or won't do that. So that is why aftermarket diffs we'll continue to grow no matter how much damage is done, and it's kind of sad imho
Old Nov 4, 2018 | 10:17 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
I see. That depends on the skill of the person, which is understandable. My approach would be to get a cover from a boneyard and then have it modified for sensors and a drain plug. That way, the modified cover could be replaced at the same time as the fluid is serviced (yeah, like anyone follows that schedule!) I'd still stay away from the aftermarket covers because of the very reasons Gale shows, being the aeration of the fluid and the starving of the pinion bearing.
Still waiting for the next video to see his results.
Old Nov 4, 2018 | 05:27 PM
MoparFanatic21
Oh I agree with staying away from aftermarket covers (except tranny pans). 99% of people don't have the skill to do what I mentioned, so they sadly go with an aftermarket cover.
Old Nov 9, 2018 | 04:53 PM
Jimythefan's Avatar
Jimythefan
Another video is out. I just knew he was going to bring a better product to market. I'm in.
Old Nov 9, 2018 | 07:11 PM
Given the amount of testing he has done, he should be able to come up with a great design, that actually works. I question the idea of putting the cooling fin intake on the bottom though...... Especially on a truck that see off-road duty.... Seems to me, putting those on top would be a better idea......
Old Nov 10, 2018 | 10:38 AM
Moparite's Avatar
Moparite
Most daily drivers towing even wheeling is not going to see 300 degrees so for most it's not an issue. There are a few other covers that he didn't test that addressed the problems with the aftermarket diff covers that he did test. His cover looks impressive but the price will probably be $300 and only available for dana 60-80.
Old Nov 10, 2018 | 01:23 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I don't think the fins will be a problem with off-road trucks since most of them are lifted. I bet they're stronger than one might think, plus Gale probably took that into consideration.
Old Nov 10, 2018 | 09:03 PM
MoparFanatic21
Only issue I could see with his cover on a TRUE Off-road rig is it could interfere with the yolk/cover skid plate
