what else should I do when changing transmission fluid and filter
Old Jan 9, 2021 | 12:55 PM
combatpaddler's Avatar
combatpaddler
Default what else should I do when changing transmission fluid and filter
My 95 5.2 2wd is due for a transmission fluid and filter change. Truck has 115,000 miles on it, electric overdrive. Any sensors or electrical components i should do while I have the pan dropped?
Old Jan 9, 2021 | 01:08 PM
Nope. Adjust the bands while you are in there, and you are good.
Old Jan 10, 2021 | 09:45 AM
Moparite's Avatar
Moparite
Put some rare earth magnets in the bottom of the pan. They will attract the metallic debris and keep it out of the filter.
Old Jan 10, 2021 | 10:38 AM
combatpaddler
Now thats an idea....how have I never thought of that all the times I've worked on transmissions ill never know.
Isnt there a sensor and switch or 2 thats internal that often goes out? Thinking about going ahead and replacing them while the pan is dropped
Old Jan 10, 2021 | 11:11 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Yeah the governor pressure sensor and I can't think of the other one at the moment
Old Jan 11, 2021 | 06:38 AM
Moparite's Avatar
Moparite
Shift solenoid.
Old Jan 22, 2021 | 08:06 PM
BigRedRam95's Avatar
BigRedRam95
I’m also getting ready to drop the pan on my transmission as it’s leaking. Truck has 101000 miles on it. I have had it since 68000 and only changed the fluid and filter. The trans is shifting good now should I adjust the bands while the pan is off? Or is it one of those things if it’s not broken don’t fix it?
Old Jan 22, 2021 | 09:39 PM
I think it is supposed to be maintenance every 30 or 60K miles, so, while you are in there, go for it.
Old Jan 22, 2021 | 10:29 PM
combatpaddler
I just picked up my filter, hopefully get around to it tomorrow. I decided not to change the sensor, because, well it's working, I think. I'm the 3rd owner of this beast, and overall she runs good. Every now and then when I have the cruise set on 70 for an extended period of time (2 hours into a trip), it kicks out of o/d and the check engine light comes on. It does it for about 10 minutes, then goes back to normal. Hopefully I'll learn more when I drop the pan.
Only major issue I've had is not finding a belt that will fit the motor, the longest one autozone had was 1/2" at least too short. But that's another thread.
Old Jan 24, 2021 | 12:56 PM
combatpaddler
Got it changed this morning. Adjusted the back band while I had the pan dropped. Took 5.5 quarts I believe to get it back to normal fill.
Remember, the bolts holding the filter are torx, don't do like I did and think it was nut. Spent 30 minutes looking for a small wrench, then the light bulb clicked.
Also, 72in/lb equals out to 6ft/lb.
