2 in body lift. What I need to know?
I got new tires. 315/70 R17. They rub so I'm doing a 2in body lift. Need to know what is all involved in doing a body lift. I did the bed with no problems. No tight wires.
doing the cab now. Did the back of cab with no problems. But when doing the front I noticed a couple of wires pulled out of a plug and also the truck rolls. So it's not in gear now. When it was in park when I started. So I know I need to adjust the shift linkage now.
other qwestions.
Do I need to adjust the steering shaft? What about the brake lines? What size gears should I run?
I replaced the leaf springs to the 2500lb each side. leveled the front springs. Aftermarket control arms for more tire clearance. 2in wheel spacers. Rancho shocks and steering damper. Added the steering gear support bar the brace with the bearing for the end of the steering bolt that bolts to the pitman arm.
other qwestions.
other qwestions.
other qwestions.
I removed the body lift that was in my 99 v10 when I got it. Best thing I did. when we went to set the box down we discovered it had banana'd a couple inches so we had to gently bend it back starting with longer bolts at each end an slowly tightening them. But yes there was bumper brackets, fan shroud brackets, t-case shifter extensions, ground extensions, steering shaft extension, filler neck extension, and probably something else I am forgetting.
Truck handled better afterwards and with the box sitting on the frame it didn't flex as much off road. It's kept my box corners from tearing anymore at the top. There is very little support for the box with the body lift in, only 6 pucks and none in the middle section (why mine was banana'd a little) where as it sits on the frame and cross members stock.
Trending Topics
I don't have the the bumper relocating brackets. But I made my own shift rod extension. That goes over the end of the rod. With two bolts that tighten down on the rod. Came out really solid. Haven't looked at the transfer case shifter yet. I can buy the bumper brackets soon. So I am good to go. Tire has rubbed a bit just on one side as I still need to replace the ball joint with an offset one on that side.
