How much power will a remanufactured 47re hold?
Old Jan 21, 2022 | 10:48 AM
Dodgefanman54's Avatar
Dodgefanman54
Default How much power will a remanufactured 47re hold?
Hey guys, looking for some advice from people who have walked this road before me. I have an 01 2nd gen that I only drive a couple of times a week that I'm thinking about upgrading the transmission on. It's in the shop currently getting a new FASS fuel system, oil pump, and a new HX35 turbo. I got a remanufactured 47re almost 2 years ago from these guys (it has 18k miles on it now), https://reman-transmission.com/trans...des/?code=47RE, and I'm just wondering if it's going to hold the extra torque from the new fuel system and turbo. If not, I'd appreciate recommended supporting mods as I've heard good things about some shift kits, trans coolers, and torque converters that can help. Any advice is much appreciated
Old Jan 21, 2022 | 11:01 AM
It has some upgrades, but, doesn't say just how much power its rated for..... I think stock it'll take 450 lbs/ft..... How much torque is your engine going to be putting out with the upgrades?
Old Jan 21, 2022 | 01:21 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Didn't the Cummins put out 505 torque is you got the HO?
Old Jan 21, 2022 | 01:35 PM
No idea. But, I think the 47R? was supposedly rated at 450 lbs/ft......
Old Jan 21, 2022 | 04:22 PM
adukart's Avatar
adukart
The HO was only offered in a manual iirc.
Old Jan 21, 2022 | 04:26 PM
adukart's Avatar
adukart
Yes keeping it cool is critical. But make sure it isn't generating excess heat in the first place. A good shift kit or a sonnax sure cure would help by increasing flow and extra holding pressure on the clutches to help them with the extra torque. A good converter can help as well. Really though staying up on your band adjustments and fluid changes as well as monitoring the electrical components in the trans is the most important thing you can do.
Old Jan 22, 2022 | 01:31 PM
Moparite's Avatar
Moparite
Depending on deep you pockets are you can get "upgrades" for it. The link doesn't give details of what parts where used(manufactures/brands).
https://transmissioncenter.net/produ...=47re-47rh-618
https://www.sonnax.com/dodge_cummins_diesel
Old Jan 23, 2022 | 03:19 PM
95RAM360's Avatar
95RAM360
After working in a shop dealing with many Cummins, I’d have to say make sure it has billet parts, billet tc and flexplate, input shaft, and don’t turn it up to much, you want power do an nv4500 swap with twin disc clutch and avoid all the common problems and the 5-7 grand trans rebuild costs. I don’t trust the autos, seen to many crumble
Old Jan 23, 2022 | 04:04 PM
00t444e's Avatar
00t444e
That transmission won't handle much more than a stock one, but those mods you listed won't had any considerable amount of HP anyway. The 47RE can be built to handle 1000hp bit it costs 5-7K to do that.
Old Jan 24, 2022 | 03:18 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
I used these parts and got most of the them from ebay. I bought a kit with most of these parts in it.
https://dodgeforum.com/forum/2nd-gen...build-kit.html
