Scan tool for fuel sync
Old Jun 3, 2022 | 07:22 AM
dodgetruck2's Avatar
dodgetruck2
Default Scan tool for fuel sync
I read through some of the stickies ect and I do apologize if this has been addressed in one. I had no luck finding the answer and that is what quality yet affordable scan tools are capable of setting fuel sync.
I would love to go all out of a snap on modus or something ect for several thousand dollars but im not running a shop and its just not practical. I have looked in the alfa obd for programming the trailer lights on the wifes durango but it appears alfa obd only goes back to 2005MY Dodge
Old Jun 3, 2022 | 11:17 AM
The Snap-On MT2500 should suit your needs for the truck. I believe it won't do 2006 or newer vehicles though.
Old Jun 3, 2022 | 01:16 PM
dodgetruck2
What cartridges would be needed
Old Jun 3, 2022 | 01:18 PM
Not sure on that.... chrysler cartridge for the right years, and personality key as well..... (I think...)
Old Jun 3, 2022 | 06:22 PM
dodgetruck2
Found one locally with a few dozen keys/cartridges, i saw dodge 84-99 on ine screen
Old Jun 3, 2022 | 10:43 PM
That should work.
Old Jun 4, 2022 | 07:15 AM
Moparite's Avatar
Moparite
If you have a second gen(5.2/5.9) you don't need a scanner, TDC #1 cylinder on the COMPRESSION STROKE set the distributor like this...
Of course if you have a scanner it will be more accurate. This should be in the sticky section if it's not already.
Old Jun 4, 2022 | 07:43 AM
dodgetruck2
Yea I've been down that path before, I never could get the truck to run right though, I've seen some youtubes on using a volt meter to set it also
