How many miles do you have on your truck!
#873
Bought our 2001 2500 4x4 Cummins used in 2001 with 30K miles.
It now has 165,000 miles.
There was a recall on the front axle,replaced the lower ball joints and track bar IIRC.
Power seat repaired under warranty.
Lift pump replaced.
Injector pump replaced.
Dashboard replaced.
Passenger window switch replaced.
Thermostat replaced.
Transmission replaced 4 months ago.
Lift pump replaced.
Dashboard replaced.
#875
1998.5 2500 4dr short bed 4X4 5.9
400,380 miles Pure stock no BS on it. Except for tires,brakes rotors 2 brake lines,battery's,rear axel seals,and front seals.The injector pump little electric box went out at 288,000.Can't get the box so new pump.Just canged heater and evaporator yesterday.And yes u joints,trans,starter and altinator are original.Valves adj every 100,000 The bad about the truck is the cheep,dash,headliner,cup holder,seats.
#879
260,432 miles. I had the transmission rebuilt at 197,000. Replaced alternator, and starter, temp sending unit and sensor , pinion seal at 210,000 Currently I'm saving up for a new motor. This one is starting to burn oil. I'm currently trying to figure out my temp gauge on dash as it reads just past the 200 mark on gauge. I put a new Standard brand sending unit in and I think it reads higher than before. My guess is the Mopar sending unit is better calibrated to the gauge. I repainted it recently. I'm also tray ng to build some cool door handles because this Tucson desert eats plastic up.
