Problem with A/C
Old Apr 22, 2007 | 11:50 AM
Eric334's Avatar
Eric334
Default Problem with A/C
This is for a Ram 1500 5.9 with 60,000 miles
Just tried the A/C the other day and all I got was warm air. I check the two fuses and they are good, so with the A/C switch on, I check the compressor and the clutch would not engage at all. Now My question is do you think it is a compressor or just needing freon. I remember owning a car that was low on freon and the clutch would kick on and off often and would get cold/warm air here and there, so I'm thinking bad compressor. Everything worked great last year, What do you guys think ?
Old Apr 22, 2007 | 12:15 PM
morrgriff's Avatar
morrgriff
Default RE: Problem with A/C
The system could be too low on refridgerant to engage the compressor. To test this, there is a pressure switch on the system that you use a paperclip or short piece of wire on to jump it off with the engine and A/C on. If the compressor runs, your low on freon.
Old Apr 22, 2007 | 12:21 PM
Eric334's Avatar
Eric334
Is that located on the compressor or somewhere in the system?
Old Apr 22, 2007 | 12:43 PM
morrgriff's Avatar
morrgriff
On the system on the top of the condenser.Look on the passenger side in the engine compartment on the firewall. It's a black canister-like thing. Should have a green plastic plug with two wires out of it. Unplug the wires and use the wire/paperclip to "short out" the terminals on the wires. With the AC and engine on, the compressor should kick on. This determins that you are low on refridgerant.
Old Apr 22, 2007 | 12:50 PM
Eric334's Avatar
Eric334
Cool, (well not yet, LOL) but thanks for the help. Now when you say short it out, will I blow a fuse or something? Also is there a small shock with doing this?
Old Apr 22, 2007 | 01:14 PM
morrgriff's Avatar
morrgriff
It will blow a fuse if there is a short in the system or the compressor is seized up, but I wouldn't expect that as you said all the fuses are good.
No worry about a shock. Still DC current running through there.
Edit: If you use a paperclip or some unisulated wire to test, just don't let it touch any other metal on the truck- you know that will blow a fuse!
Old Apr 22, 2007 | 01:49 PM
Sirhilton17's Avatar
Sirhilton17
That reminds me...
My A/C isnt working either, I added freeon, now all it does is the clutch locks up every 3 seconds or so, then lets go and it does this repeatedly weather its on A/C or not, no cold air comes from the vents...
Is my compressor shot? If so, what can I do to stop the cluctch from grabbing every 3 seconds, casue its annoying.
Old Apr 22, 2007 | 02:00 PM
lv360ram's Avatar
lv360ram
There is an electrical connector that plugs into the compressor. Unplug it and the clutch won't grab no more.
