will it push 35s
Old May 7, 2007 | 04:25 PM
ryans590's Avatar
ryans590
Default RE: will it push 35s
ORIGINAL: importkillerrr
it's all personal preference I guess. I've got35's on my h3 with stock gears and 35's on my JK Rubicon with stock gears and have no problems with any of them. I also don't expectto race many cars off the line either.
what are the stock gars in your h3 and jk Rubicon then it could be they are geared a bit lower from the factory since they are suppose to be more of an "off road" vehicle already where as trucks are built for many purposes
Old May 7, 2007 | 05:01 PM
Silver_Dodge's Avatar
Silver_Dodge
Also, what is the weight difference between your Jeep and a Dodge Ram. The weight of these trucks makes a big difference when selecting gears, not just the size tire you want to run.
Old May 7, 2007 | 08:22 PM
junkman306's Avatar
junkman306
look at my hummer h3 in my siggy...It's an 06 so it has the 3.5L 5 cyl and I have had 35's on it for a year now with no problems. Don't see why your v6 ram would have a problem. All the little import trucks and jeeps you see on the road with 35's have smaller motors than your ram....you'll be fine.
You left out that your wanna be hummer has lower gears and so do the jeeps and toyotas. You have to do a gear swap or you're gonna kill it.
Old May 7, 2007 | 10:10 PM
towguy2007's Avatar
towguy2007
yal look i have 35s on my 1500 and have no trouble with gears only trouble is tire rub at full turn gas milage is fine to
Old May 7, 2007 | 10:26 PM
stick1994's Avatar
stick1994
Is it a 5 speed? Sport model that came with 4.10's maybe? If you have 3.55's and auto I would have to call bs on ya
Old May 7, 2007 | 11:22 PM
XXL 1500's Avatar
XXL 1500
i did a gear swap on mine about 6 months ago
im sitting on 38's with 4.56's
still not enough i tihnk, but she will smoke them on demand....
i HAD 3.55's in there.... EXTREMELY hard on driveline. change your gear ratio if even
going to 35's, i say go to 4.56's if stock was 3.55, or 4.10 if stock was 3.73.
Old May 8, 2007 | 02:58 AM
Wetherman's Avatar
Wetherman
yall i dont even know how to change my gears i can put lifts but not that, how do i do it, is it hard and if so how much would it cost to get it done
Old May 8, 2007 | 04:01 AM
jnellydodge's Avatar
jnellydodge
ORIGINAL: XXL 1500
+1,
not from experience mind u but if you want to got 35's AT LEAST re gear to 4.10 gears and USE them for mudding, play, etc. for a ram....otherwise your gonna start wrecking s*#&. WAAAAY too hard on your drivetrain nomatter set you have......H3, import, stock or whatever not if its not geared right its not gonna last long.....dont belive me ask anybody who works on rear ends for a living. 35" tires is alot of tire to push with a stock v6.....regear and you'll be fine.
Old May 8, 2007 | 05:33 AM
importkillerrr's Avatar
importkillerrr
ORIGINAL: junkman306
wanna be hummer? LMAO... My wanna be hummer will outwheel your ram ANYDAY
Old May 8, 2007 | 05:43 AM
stick1994's Avatar
stick1994
[sm=icon_quiet.gif]
