factory off road rams?
Old May 19, 2007 | 10:11 PM
greenie4's Avatar
greenie4
Default factory off road rams?
i was wondering how to tell if my 2000 ram reg cab 1500 long bed is a factory off road model or a standard model, the reason i am asking is i want to put the 2 inch level spacers on the front but i see that most of the kits say not for factory off road models, my truck seems to be a little high but not sure if it because the oversized tires.the truck was repainted so there is no off roan sticker on it. i saw a post that the off roads only came in short bed but who knows if thats true.
Old May 19, 2007 | 11:35 PM
Bob5150's Avatar
Bob5150
Default RE: factory off road rams?
Well, one way to tell is to check your wheels. If they are 5-spoke 17" aluminum wheels, that's what came with the Off-Road edition. Every other Ram will have 16" wheels. I know wheels are easily interchangeable, but it's a good place to start. I do believe the Off-Roads were only avilable in the short bed style. Hope this helps a little.
Old May 20, 2007 | 12:29 AM
spaz_22's Avatar
spaz_22
look on the underside of your hood. If you have 4.10 gears stock, it's an offroad. you can also get a build sheet from dodge, go to there website, all you have to do is enter in your vin number
Old May 20, 2007 | 02:11 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
If it is a long bed, it is not an off road model. It only came as an option on short beds.
Old May 20, 2007 | 11:39 AM
greenie4's Avatar
greenie4
thanks for the replies i guess mine is just higher looking because of the tire ,maybe the previous owner put the 17 inch wheels on it,they look a lot newer than the truck.one other thing why do the bottom of the doors rot out so fast and is there a good way to fix it besides bondo?
Old May 20, 2007 | 11:44 AM
greenie4's Avatar
greenie4
cant find the build sheet on the website?
Old May 20, 2007 | 10:21 PM
Cereal Killer's Avatar
Cereal Killer
ORIGINAL: greenie4
I just make sure I always wax where the seem is real good and spray some WD40 in there everytime I wash it. Seems to work pretty good, but once it's already rotted it's too late.
Old May 20, 2007 | 10:41 PM
dsertdog56's Avatar
dsertdog56
Best way...Rust free doors from the South, clean insides and coat all crevices with POR-15
Better way... New sheet metal, a wire welder, and POR-15
The "off roadster" option (for quad cabs and short beds)included 17 inch cast aluminum wheels, 4:10 gears and a special front D44 with extra gusseting around the Diff. It also had special "hi rate" springs front and rear which lifted the truck an extra 1.5 inches in the front and 2 inches in the rear. It also made the ride extra stiff too.
You can add a 2inch spacer to you ram, but I'd sure consider getting a different track bar to recenter the axle once you've done that. Thats the reason they don't recommend you put a spacer on an off road model.
When you go to Chrysler.com you will have to email them with your vin number. It usually takes them about a week toreply. If you're really nice to your local Mopar parts guy, he can do the same thing. Some are more willing then others.
