jet performance
Old Jun 8, 2007 | 01:25 AM
Aubrey's Avatar
Aubrey
Default RE: jet performance
Indy, have you tried a performance pulley set on your 96? I see them for only a few models but don't know if they let you really pick up anything or if they cause low charging issues, etc.
Old Jun 8, 2007 | 01:47 AM
Scottr1110's Avatar
Scottr1110
i had a crank pully for awhile at idle the gen light came on at night with he headlights on
Old Jun 8, 2007 | 02:20 AM
RM_Indy's Avatar
RM_Indy
Clive, what motor do you have? Is that a 4x4 or 4x2? 5.2 should go with 50mm tb and a 5.9 best to get the 52mm.though 4x4 that tows maybe better with the 50mm as well. FASTMAN is what mostguys go with on the smaller tbs. (53mm and under) Ihad one on mine before my Hughes 55mm.
Aubrey
March 3pc alum pulleys were on my truck from 98 till I added the Prochargerat the end of 05.I underdrove the Procharger at firsttill I had a better tune.
Small performance gain from them gave better throttle response and my ets dropped a tenth.I like them for the look and added power but the gen light will come on as mentioned at stop lights. Usually only long lights at night or if heat/ac or stereo on as well.
With the 3pc set you get a smaller alt pulley so charging is better than just crank pulley only which under drives all accessories then. Newer model years you could only get 2pc cause of press on pulley on the alt.
Old Jun 8, 2007 | 03:43 PM
clive's Avatar
clive
its a 1994 2wd 5.2L. the reson im asking for help is cause i live in the uk and cant find anyone here that deals in parts for my baby!.
[IMG]local://upfiles/37514/99ED1CC1C94D45F8A1A7619A97EA6D01.jpg[/IMG]
[IMG]local://upfiles/37514/A052BCBEE51E4435B65604818CD5CB88.jpg[/IMG]
Old Jun 9, 2007 | 11:23 AM
RM_Indy's Avatar
RM_Indy
http://hughesengines.com/
http://store.summitracing.com/egnsea...earchType=Make
http://www.krcperformance.com/krc/
Hughes is a good place to order from as is Summit.
KRC is very knowledgeable but extremely slow to ship outside the US and a bit pricey
PS. your baby looks real nice andis probably pretty rare in the UK
Old Jun 10, 2007 | 10:16 AM
clive's Avatar
clive
thanks indy. she certanly turns heads here!! had a rad hose blow on me the other day paniced that i may have cooked her but she seems ok. have to see if i can get so new hoses now!
