help me make my dodge bulimic.
Old Jun 17, 2007 | 02:04 PM
IndyRamMan's Avatar
IndyRamMan
Default help me make my dodge bulimic.
I recall somewhere I read that RM_Indy's ram raced at 3800 lbs. Even without me in mine it weighs about 4500 without tonneau and tailgate. Id like to be able to drop that 700 lbs so any suggestions on what to lose or replace with lighter parts would be handy. thanks.
Old Jun 17, 2007 | 03:48 PM
dnfd737's Avatar
dnfd737
Default RE: help me make my dodge bulimic.
I assume you want to keep the interior and all streetable.
1. loose the tail gate
2. loose the spare tire
3. buy light weight alloy rims
4. when you want to run it run on an empty tank 30 gallons weighs around 240 lbs or so
5. Remove a/c system
6. shorten exaust to exit before back tires
7. Remove cooler of beer from bed um oh that one is for me!
this is all stuff I have seen others do when they drag their trucks hope it is helpful.
Old Jun 18, 2007 | 12:58 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: dnfd737
so, basicly remove ac system...
im looking for a little more agressive than that, like replacing parts with lightweight parts.
Old Jun 18, 2007 | 01:05 AM
dnfd737's Avatar
dnfd737
well ok then aluminum heads aluminum drive shaft take the inner wheel wells out plastic windsheild lexan i think is what some folks use take the back bumper off
Old Jun 18, 2007 | 01:16 AM
spaz_22's Avatar
spaz_22
lexan really isn't an option if you want to keep it street legal. Get a fiberglass roll pan. A fiberglass hood and fenders. A fiberglass bed would be pretty helpful. Lose the gas tank and put inan aluminum fuel cell...then you could even run duel exhaust out each side. They might make aluminum a arms for the dodges, idk though. Maybe some spindles as well.......aluminum drums maybe as well....
Old Jun 18, 2007 | 01:33 AM
dnfd737's Avatar
dnfd737
some place there is a company that does prerunner kits with fiberglass just about everything
Old Jun 18, 2007 | 01:47 AM
Cereal Killer's Avatar
Cereal Killer
ORIGINAL: spaz_22
Where can I find out how to do that. I wanna run dual out both sides before the tires
Old Jun 18, 2007 | 01:52 AM
Pyromanaron's Avatar
Pyromanaron
Look into a racing transmission. I'm not sure, but I think a powerglide would be pretty light, and wouldn't hurt speed either, although gas mileage will be terrible. Any excess metal on the frame is also a good candidate for removal, just don't get overzealous. You could drastically chop the top, losing both metal and glass, and would give it that cool hot-rodder look. Maybe strip the paint off? You're gonna have to get real drastic to lose 700 lbs. Is it 4WD? If so, take it all off. Aluminum radiator. No sound system, remove rearview mirror . . .
Old Jun 18, 2007 | 02:43 AM
Cereal Killer
alumium motor...
smaller lighter tires on smaller lighter wheels.
Old Jun 18, 2007 | 03:31 AM
spaz_22's Avatar
spaz_22
all you gotta do for the fuel cell is buy a fuel cell from summit or jegs and then relocate it....like where the spare tire goes or in the truck bed. And then you just run new fuel lines, you can run an external or internal fuel pump and your good to go
