PC 601 PCM internal controller failure
Old Jul 18, 2007 | 08:24 PM
spur's Avatar
spur
Default PC 601 PCM internal controller failure
I have had this PC 601 code on my truck (2001 RAM 1500 4 WD) for over a year and my engine light has remained on. The truck runs fairly decent (maybe a little sluggish) but a friend said the code meant a PCM internal controller failure and could only be fixed by getting a new PCM board??? The board would be like $1100 and I would have to take it to the dealership to be programmed. Is this all correct info?[/align][/align]I have tried to delete it and it wont go away. Any suggestions? I am sure someone knows more about this then my weekend warrior friend. Thanks in advance![/align]
Old Jul 18, 2007 | 10:45 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: PC 601 PCM internal controller failure
Call your local dealer and ask for a price on a reman controller. They are much less than new controller and has the same 12/12 warranty. Also at the same time, find out if the controller is still cover under your emission warranty. some states have 5/60 and others have 8/80.
Old Jul 19, 2007 | 09:01 PM
spur's Avatar
spur
since I need to get one anyway is there a type that would be better performance wise? Thanks!
Old Jul 19, 2007 | 11:02 PM
dhvaughan's Avatar
dhvaughan
http://www.bgperformancepcm.com/
pricing is for software programming only. the pcm is extra. they might can fix yours.
