Wheel bearings
Old Jul 29, 2007 | 09:46 PM
BIGSEXY's Avatar
BIGSEXY
Default Wheel bearings
How many front wheel bearings have you replaced?I get about a year and a half out of them.[:@]
Old Jul 30, 2007 | 12:02 AM
95ramdan's Avatar
95ramdan
Default RE: Wheel bearings
Try replacing them with an SKF bearing. I have used them for all my bearing needs, and they are good!
Old Jul 30, 2007 | 12:58 AM
ryans590's Avatar
ryans590
just changed them for the first time about a month ago. have you got bigger tires if so youll go through wheel barrings quicker
Old Jul 30, 2007 | 10:44 AM
motorbrreath's Avatar
motorbrreath
ive had my truck for a week and day 3 the left front bearings went out. $300 part, $105 for labor = rape.
Old Jul 30, 2007 | 10:48 AM
rtmorrisjr's Avatar
rtmorrisjr
My father just replaced his for thesecond time. Hes got 290,000 on his. They were really bad but never made any noise. So if you average that out its 145K per set (Stock, replaced, now replaced again) So with that said, he shouldn't have to change them again until he hits 435K. But he only has 265/75/16 on the truck (Stock was 245/75/16). Never had any bigger tires. Also, my truck has 100,000 on it w/ original wheel bearings. So i would say you have something else wrong with the front end of that truck. Just my 2 cents tho.
Old Jul 30, 2007 | 10:52 AM
motorbrreath
bigger tires will destroy bearings. They took my wheel off and said my bearing assembly was melted on the wheel. replaced the assembly, good as new. thats what happens to a truck that stays in the mountains all the time. salty and sandy roads = rusty everything. gotta love dodge!
Old Jul 30, 2007 | 09:43 PM
Socha_62's Avatar
Socha_62
Dodge isn;'t the only one that uses unit bearings...
I got 100k out of my factory set.
Its not really bigger tires that kill the unit bearings its wheels that stick the tires out further then stock. Any wheel is crazy backspacing is going to kill unit bearings even if they're stock size tires.
Also taking corners fast and hard kills them. So if your the type that always takes corners fast or pulls into parking spots at mach 9 thats your problem.
Old Jul 30, 2007 | 09:54 PM
padodgeram's Avatar
padodgeram
mach 9...lol
