hollowed conv.
Old Jul 31, 2007 | 09:46 PM
  #21
THEGOLDPRO's Avatar
THEGOLDPRO
Default RE: hollowed conv.
stock exhaust besides the gutted cat, and i have a 360, but i'd imagine the 318 would sound alot alike.
Old Jul 31, 2007 | 09:54 PM
  #22
Moparkid032's Avatar
Moparkid032
ORIGINAL: Fox Fader
I've hollowed out a cat on my Bronco back in 2000-01 and 1 1/2 years ago on my Toyota P/U,
it won't hurt the truck at all, but it does give the tunneled sound in that area.ALSO I believe is worse on exhaust
flow than having a properly working cat.
Our cats bolt on right?
If you weld, I'd cut the flanges off and weld them to the proper length/size pipe, bolt it back inand be done with it.
A shop did this on my 300ZX back in '91-92, worked perfect.
mine isnt..its connected to the Y-pipe..i am in the same situation my CAT is clogged and i was thinking of gutting it..but i came across this and it didnt seem expensive so i got it..now just waiting for it to be delivered
http://store.summitracing.com/partde...p;autoview=sku
Old Jul 31, 2007 | 10:21 PM
  #23
Dodgeboy328's Avatar
Dodgeboy328
That's the cat I was looking at. I talked about it earlier. Do you know if it has a place for the two O2 sensors? I couldn't tell by the info they gave.
Old Jul 31, 2007 | 10:25 PM
  #24
Dodgeboy328
I take that back. I didn't enlarge the picture the first time. I see where the sensors connect know.
[sm=forgetit.gif]
Old Jul 31, 2007 | 10:42 PM
  #25
Fox Fader's Avatar
Fox Fader
hmmm, not for the '01
Old Aug 1, 2007 | 01:34 AM
  #26
milkdud110's Avatar
milkdud110
does this hurt the motor any way i am asking because i have no idea i was told once that if you take it off it will fry the valve's just want to know might take mine off if it dosent hurt it
Old Aug 1, 2007 | 05:58 PM
  #27
THEGOLDPRO's Avatar
THEGOLDPRO
i have never heard of it burning up valves, i wouldent worry about it.
Old Aug 2, 2007 | 12:24 AM
  #28
milkdud110's Avatar
milkdud110
so if just take mine off that will work right no worry about hurting stuff?
Old Aug 2, 2007 | 12:33 AM
  #29
padodgeram's Avatar
padodgeram
depends if you have emmisions or not , taking the cat off mite hurt the performance some mite drop the mpg to. when mine was bad i just replace it with a highflow of course in pa we have emission laws . and if you do take it out where are you gonna install the O2 ? need another bung to plug in the pipe..and even if you do that you mite throw a CEL
Old Aug 2, 2007 | 12:43 AM
  #30
milkdud110's Avatar
milkdud110
my o2 sensor is not on the cat its up like 4 inch away i am sure i will double check
no emmisions around me live in ohio
if i take the cat out i will hurt the performance? i thought it would be better?
