electrical problem?
Old Jul 31, 2007 | 07:26 PM
justin124's Avatar
justin124
Default electrical problem?
1999 Dodge Ram 2500 radio and dome light quit working same day. Has anyone heard of this? What do those two have in common?
Old Jul 31, 2007 | 07:45 PM
2001dodgeram1500's Avatar
2001dodgeram1500
Default RE: electrical problem?
first thing to check would be the fuse's
good luck
Old Jul 31, 2007 | 08:11 PM
froesen's Avatar
froesen
IOD fuse, i believe #12 in the cab instrument panel, could be at fault. it's the one with the black plastic tab holding it from coming all the way out, i had to break mine to get it apart...but that fuse feeds both those loads.
Old Jul 31, 2007 | 08:33 PM
txredneckmedic's Avatar
txredneckmedic
Check your wires and see if you melted your wires...thats what happened to me
Old Jul 31, 2007 | 08:56 PM
ryans590's Avatar
ryans590
yep ill bet IDO fuse as well, if not that one check the rest
Old Aug 5, 2007 | 11:26 PM
justin124's Avatar
justin124
It was the IOD fuse. You guys are awesome! I had that fixed that same night, thanks to you.I don't work on cars much. I'm a helicoptor mechanic, so hey...if anyone needs help with their Blackhawk, let me know. Thanks again.
Old Aug 6, 2007 | 01:31 AM
froesen's Avatar
froesen
the only problem with my blackhawk is that i don't have one...
Old Aug 6, 2007 | 06:10 PM
2001dodgeram1500
me either, I would like to own an Apache AH-64 Helicopter those are too awesome.
Old Aug 6, 2007 | 07:33 PM
cjsdad's Avatar
cjsdad
Pull your cigarette lighter out and check to make sure it hasn't unscrewed itself! Obviously make sure it isn't hot to the touch and hold onto the heating element in one hand and the **** in the other. Check to see if it will screw together. If the heating element is stuck in the socket, pull the fuse out and use needle nose pliers to fish it out and reassemble. Then reinstall fuse.
I saw this syndrome many times during my 15 years installing stereos!
