Another grinding noise
Old Aug 1, 2007 | 12:53 AM
jasonjuch's Avatar
jasonjuch
Default Another grinding noise
I went 4 wheeling on just a dirt road with some bumps in it and a moderatly dry field yesterday and mesed up something. Now when im in 2 wheel drive and start from a stop i hear a grinding noise only when im on the gas and starting to accelerate but theres no noise when im at a good speed. The grinding sounds like its from the trasfer case and maybe the shifter just isnt seated properly in 2 wheel drive? When i start slow and keep accelerating reall slow i can wait for the noise and let of the gas and just get it up to speed and i hear no noise. From other posts they say a vacume swith might make that happen? But mine is only when it starts up. Any knowledge??????
Im planning to change all the fluids tomorow and maybe check out the shift linkage adjustment and thats all the Haynes Repair Manual says i can do. Thanks for the help.
Old Aug 1, 2007 | 04:51 AM
dhvaughan's Avatar
dhvaughan
Default RE: Another grinding noise
STOP - don't drive it.
if you have a noise from the transfer case you should stop driving it, as it may quickly go from minor to major $$$. i'm not an expert but a common failure is a snap ring that lets the shafts start flopping around, which then eats up everything else. in the link below, reman t-cases are around $1,000. so don't make yours worse if you can help it.
here's a link Hank posted for a heavy duty snap ring replacement. looks like an easy 'on the truck' repair.
https://dodgeforum.com/m_901176/tm.htm
the web site is pretty sloppy with a lot of broken links, but if you go directly to here http://www.drivetrain.com/
it navigates a little better. they have some good diagrams and info.
Old Aug 1, 2007 | 09:57 AM
jasonjuch's Avatar
jasonjuch
ok thanks. im going to check the snap ring out right now since that makes since. When its in 2 wheel drive then everythings loose because of that so it grindes but in 4 wheel everything is meshed together better so the grinding stops.
Old Aug 1, 2007 | 11:48 AM
jasonjuch's Avatar
jasonjuch
I FOUND IT. of course it was that snap ring. Thanks for the help. Ill just go down and buy another stock one to get it running then upgrade to the heavy duty later. Thanks a lot
Thats an easy thing to check too. I just removed the rear drive shaft and 4 skrews and the ring fell right out in my hand.
Old Aug 1, 2007 | 01:10 PM
jasonjuch's Avatar
jasonjuch
Is there a way to delete this thread now that i have the problem fixed or does it just stay on the site?
Old Aug 1, 2007 | 03:05 PM
rtmorrisjr's Avatar
rtmorrisjr
it stays on the site. its a good thing tho. now when someone searches for a problem like this they can easily access the answer.
Old Aug 1, 2007 | 06:12 PM
froesen's Avatar
froesen
just make sure you put a little rtv on the tailshaft housing on reassembly, which is what's done from factory, that whole tcase is rtv'd or something similar. I put one of those tcase saver rings in, very easy to do, and there's no way that it would break, make sure you use the locktite too, one of those bolts backing out on the collar would cause just as many problems!
Old Aug 1, 2007 | 08:30 PM
jasonjuch's Avatar
jasonjuch
so you just bought the transfer case saver from the same link that is posted above? Can it be purchased from a place like Auto-Zone? I went to every store in the city even transmission shops and no one except the dealer could even order the snap ring so right now $7 later I have one coming tomorow morning at the dealer but hopefully soon i can upgrade it to the heavy duty snap ring. But since the snap ring is the weakest part, if you replace it with a heavier duty one do you think another part in the Tcase will break instead of the snap ring. Its a pretty cheap fix as it is now if you catch it in time.
Old Aug 1, 2007 | 08:43 PM
jasonjuch's Avatar
jasonjuch
The transfer case saver is $64.99 on this site
http://quad4x4.com/Dodge%20Transfer%20Case%20Parts.htm
And only $39.29 on this site
http://www.drivetrain.com/gillies/Tcasesaver.html
-it looks like a good deal to save having to rebuild the t-case
Old Aug 3, 2007 | 09:26 PM
jasonjuch's Avatar
jasonjuch
How do i insert this new snap ring? do i just push it on really hard or should i dissasemble parts in order to put it on. I dont want to bend or break it.
