screwed help??
Old Aug 2, 2007 | 02:53 PM
bigblack 21's Avatar
bigblack 21
Default RE: screwed help??
ok i checked all the oil and stuff and theres no leaking and the no oil in the radiator and still nothing.. anything else??
Old Aug 2, 2007 | 03:06 PM
Captain Squalus's Avatar
Captain Squalus
This isa long shot
Is the TQ still bolted to the flywheel?
Old Aug 2, 2007 | 04:09 PM
castironman's Avatar
castironman
faulty valve body, oil pump damaged or governor pressure solenoid. Didi you ever got any check angine light ?
Good luck.
Old Aug 2, 2007 | 05:22 PM
rhaines00ram's Avatar
rhaines00ram
Id look at the linkage put on the ebrake and have some one move the shifter while you are under there and make sure it is moving on the trans . I never herd of a trany just going out all at once . Good luck
Old Aug 2, 2007 | 06:12 PM
bigblack 21
i had it moving a lil bit today like a foot then just sat and reved so its gotta be something with the linkage beacuse its like not engaging it i can slide the shifter from rev,all the through
