front disc break SEVER wear
Old Aug 6, 2007 | 09:39 PM
2500 mopar's Avatar
2500 mopar
Default front disc break SEVER wear
i just had my breaks redone new roters and a new front pasengers side caliper, but the drivers side roter has EXTREME wear marks, they have only about 3000 miles on them and i havent been hauling extreamly heavy loads. any answers?
Old Aug 7, 2007 | 12:20 AM
JoeC1981's Avatar
JoeC1981
Default RE: front disc break SEVER wear
By wear marks do you mean gouges? Make sure the friction material didnt break off at all. Also the caliper could be dragging/ not releasing right. Were the caliper slide pins and contact points lubed before they were put back on?
Old Aug 7, 2007 | 01:21 AM
atcsat64's Avatar
atcsat64
Who did the work?
Old Aug 7, 2007 | 10:02 PM
2500 mopar's Avatar
2500 mopar
I BELIEVE THE GUYS WHO DID IT DID A S**T JOB
THANKS A LOT
Old Aug 7, 2007 | 10:10 PM
dillonjm's Avatar
dillonjm
Sounds almost like they didn't put new rotors on..[&:]
Old Aug 7, 2007 | 10:14 PM
2500 mopar's Avatar
2500 mopar
no they did but the passenger side looks like is never been used. they drivers side looks like i have been going with out a brake change for about 100,000 miles my truck only has 67,000 miles.
Old Aug 8, 2007 | 04:44 PM
kidvillain's Avatar
kidvillain
The exact thing happened to me................turned out the new caliper they put on was defective..........if only 1 side (inner or outer) on the rotor is worn badly, then you have a caliper binding or the guides arent lubed at all
Old Aug 9, 2007 | 12:29 AM
atcsat64's Avatar
atcsat64
But 2500 you had it done at a shop, right? Did you take it back to see what they said?
