the imfamous Tire and Wheel Question
Old Aug 14, 2007 | 05:47 PM
Mudbone25's Avatar
Mudbone25
Default the imfamous Tire and Wheel Question
Ok so i just got my 3inch lift done on my 94 ram 1500 4wd and now its time for some new feet.
Im looking at a set of cragars chrome soft 8 wheels 15x10 5x 5.5 bolt circle with 4" of backspacing. and -38mm offset
would these rims rub. if so why.. is it a backspace issue....
the other choice was to go with a 16x8 with a 5 inch backspace..
If anyones run these wheels let me know.
Old Aug 14, 2007 | 09:32 PM
Socha_62's Avatar
Socha_62
Default RE: the imfamous Tire and Wheel Question
They shouldn't, looks like enough BS
Old Aug 14, 2007 | 09:48 PM
Cereal Killer's Avatar
Cereal Killer
Depends on how fat of tires you want to run.
Old Aug 14, 2007 | 10:09 PM
dsertdog56's Avatar
dsertdog56
Depends on the backspacing and if your lift included longer arms to recenter the axle. Google "scrub radius" and read the information. Factory rims have about 5 inches of backspacing, add an inch to the outside for your 8 inch rims and an extra inch if you go with 4 inches of backspacing. FYI...offset rims tend to increase the load on your bearings...now I didn't say it would wear them out, just increase the load.
Old Aug 15, 2007 | 09:19 PM
Mudbone25's Avatar
Mudbone25
well ive decided to stuff a set of 285's on the stock 16x7's since i only have about 3 weeks till i go back to college.. Im going to go for the 16x8's when i come back for winter break...
Whos got some numbers on 16x8 rims as far as backspacing..
Lets turn this into a Wheel and tire combo thread. Post your tires size and make as well as wheels with backspacing. Note if you had any rubbing with this combo.. Could be a usefull thread for people..
Thanks guys ive leand a ton of stuff about my rig here you all know your stuff... Keep it going..
Old Aug 15, 2007 | 10:14 PM
blkbaretta's Avatar
blkbaretta
ORIGINAL: Mudbone25
I've got a set of Goodyear 305/70/R16's on the stock rims of my Ram. I also have a 3 inch lift and I get a little bit of rubbing when the wheels are fully turned, other than that, no problems. However, within the next few months I plan on getting some black/machined 16x10s to go on mine. Good luck with yours.
Old Aug 15, 2007 | 10:31 PM
wayneo360's Avatar
wayneo360
ive got a similar question as well.. my buddy has a 2001 ram 4x4 and hes got 305/70/16 on the stock sport wheels and they rub bad, there so nubby all u hear is ding ding ding, right now i have 285/75/16 on my stock rims and only rub at full turn on a downward hill pretty much, i am going to install my 2 inch level kit and want to get 33x12.5's on my 2001 ram 4x4 and i know im going to need new rims because they will rub the **** out of my suspension arms like they do on my buddys, so wat should i be looking for when im looking at rims so they will have enough backspacing or watever else so i will have no rub? will i need to get wheel spacers or will some new rims just fix that by themselves?
Old Aug 18, 2007 | 01:46 AM
Mudbone25's Avatar
Mudbone25
be carefull about 15" rims on a 2001 since 99 i believe dodge went to a 2 piston caliber setup which takes up to much room for a 15" rim.. ive herd that depending on the rim you may be able to grind off a bit of the caliber to make them fit.
