Troubles installing ABS rear dif speed sensor.
Old Aug 16, 2007 | 11:34 AM
bluestraw's Avatar
bluestraw
Default Troubles installing ABS rear dif speed sensor.
Hello all,
I was in the process of installing an ABS speed sensor to hopefully resolve my 'ABS/brake' dash trouble light issue. But, I've run into a little problem.
Here's the ABS sensor that was sold to me at CarQuest.
http://i186.photobucket.com/albums/x.../ABSsensor.jpg
Now here are a couple of pics of my rear diff.
http://i186.photobucket.com/albums/x...aw/reardif.jpg
http://i186.photobucket.com/albums/x...iflocation.jpg
Now I consider myself somewhat mechanically inclined, but an having a little difficulty here.
Oh yeah, she's a 2001 5.9 360 2X 2500.
Old Aug 16, 2007 | 11:58 PM
dhvaughan's Avatar
dhvaughan
Default RE: Troubles installing ABS rear dif speed sensor.
i don't understand what your question is... but...
there are 2 speed sensors on your truck. one is on the transmission, and one is in the top of the rear differential. i think the picture you have is the transmission sensor. i'm looking for a picture of the one on the rear diff, but haven't found it yet. the one on the rear diff is right on top of the pumpkin, with a electrical connector on it.
Old Aug 17, 2007 | 12:44 AM
bluestraw's Avatar
bluestraw
ORIGINAL: dhvaughan
Edited my post. Added this picture.
This is a picture of the connection on top of the pumpkin on hte rear diff.
So, your sayin that Car Quest might have sold methe wrong sensor? I specifically told him the one that goes on the rear diff.
Old Aug 17, 2007 | 01:21 AM
dhvaughan's Avatar
dhvaughan
yes, they sold you the wrong part. (...although sometimes it is the trans sensor that's faulty...)
i went to rockauto.com and put in year/make/model and searched on sensor.
i found speed sensor (transmission) with pic like yours, and abs sensor (differential) with no pic.
so i went to web page for 'standard motor products' and chose 'catalog lookup' - 'application'
put in yr/make/model.
under product - scroll down to SENSOR-SPEED
see AT TRANS (SC104) and VSS-DIF (ALS203) click the BG for a pic
http://www.smpcorp.com/web_app/catal...liccatalog.asp
trans
http://www.smpcorp.com/web_app/catal...trSearch=SC104
rear diff
http://www.smpcorp.com/web_app/catal...rSearch=ALS203
Old Aug 17, 2007 | 08:12 AM
rtmorrisjr's Avatar
rtmorrisjr
you def got the wrong one. was it expensive? you might just replace that one, and replace the rear one. don't know the cost of them tho.
Old Aug 17, 2007 | 08:25 AM
bluestraw's Avatar
bluestraw
ORIGINAL: rtmorrisjr
Not really. It was only $19.+ plus tax. I think I'm just gonna replace both of them, so I don't have to think about them.
Thanks alot for the info guys.
Old Aug 17, 2007 | 04:38 PM
xbgfalcon07x's Avatar
xbgfalcon07x
Yep, that's definitely your transmission speed sensor. I have the same problem you have currently and just purchased the rear diff wheel speed sensor, which I could only purchase through the dealership. I would return the transmission speed sensor because normally the only fault in those is that the internal magnet is covered on the outside by lots of metal shaving blocking the connection. I just cleaned mine off.
Old Aug 17, 2007 | 10:46 PM
dhvaughan's Avatar
dhvaughan
ORIGINAL: xbgfalcon07x
good tip.
Old Nov 23, 2007 | 11:45 AM
eyebrowski's Avatar
eyebrowski
I recieved my sensor from rockauto.com and it has a plastic cap on it that I am assuming needs to be removed because it doesn't fit in the rear diff and the sensor I took out had an exposed wire coil. How does this thing come off?
Old Nov 23, 2007 | 11:55 AM
eyebrowski's Avatar
eyebrowski
FYI, the "cap" isn't a cap and the old sensor broke off in the rear diff.
