Decided to do an engine build.
Old Aug 24, 2007 | 11:54 AM
Bouncer88's Avatar
Bouncer88
Default Decided to do an engine build.
Well this thread is going to progress as I rebuild the engine for my Indy Ram. I plan on putting all new parts in it, all new seals, bearings, crank, rods, pistons, heads, rockers, etc. etc. etc. I also plan on doing forced induction, no not supercharged but turbo charged. I happen to have a Garrett Turbo that needs to be rebuilt which I am in the process of doing only thing is I don't know if it's big enough to supply any noticeable power to my engine.
Here are pics, you guys tell me.
Old Aug 24, 2007 | 02:30 PM
Socha_62's Avatar
Socha_62
Default RE: Decided to do an engine build.
Looks kinda small, whats it off of? Or is it a universal type thing with no real application?
It'll spool up quick though, so decent off the line, any idea how much boost it can put out?
Old Aug 24, 2007 | 08:13 PM
Bouncer88's Avatar
Bouncer88
ORIGINAL: Socha_62
Off of a Nissan Silvia in japan, max psi is 12, I have 2 of these so maybe twin turbo?
Old Aug 24, 2007 | 10:10 PM
Socha_62's Avatar
Socha_62
Twin would be bad *** but you'd have to talk to RM_Indy or call up the Hughes and see how much boost they can handle and such. I have no idea honestly.
Old Aug 25, 2007 | 07:34 AM
Bouncer88's Avatar
Bouncer88
ORIGINAL: Socha_62
I probably will end up talking to someone, I think that twin turbo, 5 psi per turbo, 10 psi total, would not be bad at all.
Old Aug 26, 2007 | 08:06 AM
RM_Indy's Avatar
RM_Indy
AR48 is popular with the 1.6-1.8L civics andIve seen them on ebaywhere the seller rated themfor up to 350hp and 27psi boost. On a 5.9 you would have to have 2 of them. On a built motor would probably restrict hp beyond 5k rpms I suspect but should spool up fast. Id do more research to find out for sure.
Old Aug 26, 2007 | 04:55 PM
Bouncer88's Avatar
Bouncer88
ORIGINAL: RM_Indy
Well I started to look into two GT series turbos, probably either GT25's, GT35r's, or the massive GT40r's. I just am unsure if the block could handle boost from the GT series.
Old Aug 31, 2007 | 04:27 PM
PILOTGUY's Avatar
PILOTGUY
If those are from a silvia, they are gt-25(s). At the boost pressure you are talking about, those should do the job well with very, very quick spool up. The gt-25 series is used on engines usually smaller than 3 liters, hence it coming off of a 2 liter nissan motor. I with the internal engine work you are doing, 5psi is not even going to begin to hurt your engine.Getting up intomid-teens in boost pressure might make mestart to worry about the block though.Good luck and keep us informed!
