cold air... which is better?
Old Aug 26, 2007 | 02:20 PM
2500 mopar's Avatar
2500 mopar
Default cold air... which is better?
K+N.............. Summitracing.com 285.00... add 11hp
Airaid..............Summitracing.com 195.00...add11hp
AEM...............Summitracing.com 270.00...????????
which is better for the price?
Old Aug 26, 2007 | 02:40 PM
heybuddy1901's Avatar
heybuddy1901
Default RE: cold air... which is better?
https://dodgeforum.com/m_613741/tm.htm
that one, hands down, save a ton of money too
Old Aug 28, 2007 | 07:20 PM
mooseariss's Avatar
mooseariss
Yeah have to agree with the last post. If you use an open element airfilter, like an Old School hot rod, you will get the best under hood responce. As well as the great sound when you accelerate!
But if your in California, from what I have read, thats a no go. You have to use a C.A.R.B approved after market set up. And from what I have read, only K&N and Airaid are the only manufactures out there that have that approval.
Old Aug 28, 2007 | 07:23 PM
heybuddy1901
thats why u just keep the stock assembly and throw it on for smog
only takes a couple minutes to swap em.
Old Aug 28, 2007 | 10:20 PM
2500 mopar's Avatar
2500 mopar
how much did you pay for your air intake, and where did you get it?
thanks
and will this work on a stock throttle body, on a 5.9 liter V8?
Old Aug 29, 2007 | 01:17 AM
heybuddy1901
i dont have that kit
yet...
im ordering mine after the 14th of sept. as i have other costs that are more important than an intake
read that thread, itll tell u everything u need to do
Old Aug 29, 2007 | 09:31 PM
2500 mopar's Avatar
2500 mopar
guess what im sold,but i have a few questions, just try to answer them your best
i have a 5.9 liter, does this matter?
my pcv hose goes from the pcv valve and to the left side of the engine the stock air housing maybe tomarrow ill get a pict if you need it...
thanks again
Old Aug 29, 2007 | 09:39 PM
aim4squirrels's Avatar
aim4squirrels
5.9 won't make a difference
You don't touch the pcv hose; that hose goes into the intake manifold, not the air cleaner. It's the other hose that gets replaced with a breather (the clean air side). Just remove that hose and knuckleand stick a 1" breather into the valve cover.
Old Aug 30, 2007 | 05:05 PM
2500 mopar's Avatar
2500 mopar
yes you were right about the pcv valve hose going into the intake as well as the brake hose on the drivers side, however there is a hose going into the air cleaner housing that goes to the valve cover on the passengers side, is this the one that you said put a breather on?
one question that hose that goes into the air cleaner housing is filtered air, by puting a breather on it the air wouldnt be, or would it with the right breather?
THANK YOU
Old Aug 30, 2007 | 07:54 PM
2500 mopar's Avatar
2500 mopar
who do i order from?
