Plugs changed. I found something.
So my CEL comes on today.. check the code- gives me misfire plug 6.. so waited a few hours until the engine was cold, tore out all 4 of the back half plugs.. and ended up finding that I cooked the cyl 5 Plug.
All 4.. back half of the engine left side right side.. front / rear, for both.
Passengerside
Front then Rear.
Driverside
Front then Rear.
makes me quite happy once in awhile to see a CEL.. and I am thankful i keep spare plugs in my truck incase I was somewhere on a day where things are closed. .. like a damned sunday evening..
I know why they cooked.. but .. im surprised that noone has made any that can withstand the heat.
Passengerside
Front then Rear.
Driverside
Front then Rear.
RE: Plugs changed. I found something.
i replaced the front 4 about 6 months ago.. then these 4 now.
yeah i know i should've replaced all 8 at the same time. but i didnt, it was getting to late and the cold was starting to affect me.
but the next round of plug replacement i will swap all 8.
There is a official TSB from Dodge
about cylinder 5 having a problem with
'crossfire' if the ignition wire for other cylinders
run too close and too parallel
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
it is also possible the plenum gasket has developed a leak
which can be next to any of the cylinder runners
but generally tends to be near the back.
ORIGINAL: HankL
Trending Topics
Bosh Platinums? (Ugh)
Looks like the insulator broke off. Could have been defective or possibly cracked from dropping?
I guess you already changed em but I would reccomend a different brand of plug.
In 20 years as a dodge tech I've had more diveability complaints from people running Bosh platinums than any other singular component. I wouldn't run 'em in mine if they were free!
