Drive line lash
Old Aug 27, 2007 | 08:08 PM
Quakindude's Avatar
Quakindude
Default Drive line lash
Hello all. New guy here. I just got a 1996 1500 4x4 with atuo trans and 5.9L engine. 94k miles. I think I already know the answer to this question, u-joints, but would like to get your opinions since you've owned these trucks linger than I have.
Putting the truck in gear gives a little bump. Then, when you go down the road, shift from 1st to 2nd is a little rough, feels like drive lash/bump. 2nd to 3rd is the same way though not as pronounced. Shift into OD is fine. Downshifts aren't as pronounced either, but you can still feel it. There's no tranny slippage and the oil is well used, but nicely red and somewhat sweet smelling. No metallic floaties or smell.
So I'm thinking U-joints because they are obviously well worn from a visual inspection with a healthy coating of rust on them. Do you folks agree with this diagnosis and if so, does the drive shaft have to go to a machine shop to get the bearings pressed in like on my Jeep Wrangler? Or can I do them in the driveway?
I've got a pretty good selection of tools, pretty decent ability mechinically and a strong desire to do the work myself.
Any help you can provide will be greatly appreciated.
-Tom
Old Aug 27, 2007 | 08:20 PM
motorbrreath's Avatar
motorbrreath
Default RE: Drive line lash
mine does the same thing, i got the u joint diagnosis today. are u hearin a squeek or grind by any chance?
Old Aug 27, 2007 | 09:10 PM
Quakindude's Avatar
Quakindude
No, no squeaks or grinding. I can feel it bump a little though. The harder I get on the gas, the less it does it. If I let it shift real softly, it bumps harder.
Old Aug 27, 2007 | 10:05 PM
Sinister's Avatar
Sinister
in reverse is it a loudish clunk? sometimes you can hear it, then definately ujoints.
when you get them replaced, be sure they have ones with the greasenipple on them.. and take a look at your steadybearings at the same time while the axle is off.
I would recommend going to a shop for them to be replaced. after watching the guy fight and fight with mine for awhile, im glad i didnt rip it out in the driveway and try doing it myself.
Old Aug 28, 2007 | 12:01 AM
nhlbill's Avatar
nhlbill
If you want a stronger joint, get the u-joints that do not have a greasable zirk.
Old Aug 28, 2007 | 09:12 AM
Quakindude's Avatar
Quakindude
Yes, reverse does give a good clunk as well. I'll go with the U-Joints. Since I got this truck mainly for twoing my boat, I don't want totake any chances with them anyway. I've also got some brake work to do on this truck. It sat for a longish period a couple years ago and the front rotor are pitted bad enough to need replacement. It affects the braking a bit, so will probably pull the drive shaft and take it somewhere to have the U-Joints replaced and do the brakes while waiting for that to come back.
Thanks for you input folks!
Old Aug 28, 2007 | 09:25 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Good idea to take it somewhere else for the u-joints. In my younger days I replaced them in my driveway, but now I choose my battles, and changing u-joints is a battle I choose not to have. Let someone with a hydraulic press have the fun. It's worth it in saving bruised knuckles and a sore throat from yelling.
Old Aug 28, 2007 | 02:51 PM
jnellydodge's Avatar
jnellydodge
ORIGINAL: Quakindude
-Tom
"No, no squeaks or grinding. I can feel it bump a little though. The harder I get on the gas, the less it does it. If I let it shift real softly, it bumps harder."
Pretty good bump shifting into reverse, bump/clunk between 2nd and 3rd, I personallyknow of 3 Rams that do this, 2 are 98's and ones a 99'. One of these three trucks is mine, the other two are my hunting buddies. I've hadmine to 3 different shops, each one couldnt find anything wrong with it.As for their trucks,they've been told its normal. It hasdone it for 50k miles since i bought the truck, never given any problems, theirs have done it for as long as they could remember. I've accepted it as "normal,"as have they.
Old Aug 28, 2007 | 05:28 PM
Quakindude's Avatar
Quakindude
Thanks for the reply. I've bought the U-Joints for $20 each and will have a shop replace them for $40 when I take the truck in to have the Converter and exhaust replaced. It's so cheap to have it done I may as well rule those out. If it still does it after the U-Joints and I check out the rear diff, I'll chalk it up to the the truck's normal behavior.
