Rotors!!!!
Old 09-01-2007, 10:13 PM
reils49's Avatar
reils49
reils49 is offline
Default Rotors!!!!
I drive a '99 2500 4x4. Today I dedcided to replace my front break pads, and in the process discovered that my rotors should be replaced as well. I bought the parts, and set to work. Pulled the tire off, got the breaks off fine. I removed the axle nut and all 4 knuckle bolts, and the rotor wouldnt come off. I tried spraying it with lube and tapping it with a hammer. It still wont come off. Any suggestions would be great.
Old 09-01-2007, 10:28 PM
Socha_62's Avatar
Socha_62
Socha_62 is offline
Default RE: Rotors!!!!
Hit it harder. You already said its scrap right? Can't hurt it. They get rust welded on
Old 09-02-2007, 12:32 PM
tazman6789's Avatar
tazman6789
tazman6789 is offline
take a torch to it heat the snot out of it then mash it with a bigger hammer
Old 09-02-2007, 12:45 PM
Moparkid032's Avatar
Moparkid032
Moparkid032 is offline
or do what i do..find the biggest hammer you got got and take your anger out on the son of a gun..
and outta curiosity..why did you take the axle nut off and the knuckle bolts off for the brakes?? unless your doing other work i dont think thats needed...but i could be wrong...
Old 09-02-2007, 02:13 PM
reils49's Avatar
reils49
reils49 is offline
took the axle nut and knuckle bolts off to replace the rotors. thats where my problem is, i still cant get the damn things off.
Old 09-02-2007, 02:18 PM
reils49's Avatar
reils49
reils49 is offline
Is there anything holding the rotor on; other than the axle nut and 4 knuckle bolts? I would feel like a jackass, after all the time ive spent on this to find out I missed a nut or bolt or cotter pin somewhere.
Old 09-02-2007, 03:31 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
I've never gotten one off without having to crack it a few times without a ball peen hammer. When you think about it, the entire weight of the front end of the vehicle leans on these things, they're built for more abuse than you could probably throw at em with a hammer.
Don't be afraid to hit it on the top or sides as well. Sometimes where you hit it is more important than how hard.
Old 09-02-2007, 06:29 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Jr. Mechanic is offline
Dude you still havent gotten those off? Sorry I couldnt have been more help!
Old 09-02-2007, 07:10 PM
padodgeram's Avatar
padodgeram
padodgeram is offline
wow , on a 4x4 all you had to take off was the break cailber then the rotor comes right off
Old 09-03-2007, 01:13 AM
ICEMAN_CH's Avatar
ICEMAN_CH
ICEMAN_CH is offline
All you need to do is take of the two bolts holding the caliper on and then the rotor should slide right off.
Quick Reply: Rotors!!!!
