Clearance Lights
Old Sep 8, 2007 | 11:25 AM
motorbrreath's Avatar
motorbrreath
Default Clearance Lights
Anyone know where i can find some cheap clearance lights (cab lights, yellow lights, night running lights, whatever yall wanna call em)? Also has anyone installed these themselves, if so, PITA or no?
Old Sep 8, 2007 | 12:26 PM
RamManRiley's Avatar
RamManRiley
Default RE: Clearance Lights
GO TO ADVANCE auto parts 20$ and boom u got them. pull the head liner dwn and drill 5 holes which are cut out for you then wire them into the head light switch.
Old Sep 9, 2007 | 12:23 AM
e_secrist's Avatar
e_secrist
Make sure to put rubber grommets in the holes you drill. This will keep the wires from rubbing on the metal and causing a short- or worse a fire. If you hook it up to your headlight switch it will burn it up also if there is a short.
Old Sep 9, 2007 | 01:44 AM
BlueBeast2's Avatar
BlueBeast2
wouldn't mounting them to a bar be a better option?
Old Sep 9, 2007 | 08:26 AM
motorbrreath
ORIGINAL: BlueBeast2
nah, im talkin about the little yellow lights that run along the cab, they supposed to be mounted to the truck roof.
appreciate the info guys, i would do it my self im just worried about messin somethin up.
Old Sep 9, 2007 | 09:23 AM
BlueBeast2's Avatar
BlueBeast2
OH lol mounting them too the roof makes since then
Old Sep 9, 2007 | 11:49 AM
Chopper1's Avatar
Chopper1
From what everyone has said in the past the roof already has the places for them inside. When my headliner was out I did notice gaps for where they would be. By the way, pulling the headliner on an extended cab is a longer job than expected. PITA
Old Sep 9, 2007 | 11:54 AM
dishdude2k's Avatar
dishdude2k
i put clearance lights on my 99 ram i used to have.. they looked good.. the headliner wasnt an issue.. i just pulled the front of it down so i could get access to the wires after i put them in .. to me.. the more PITA was on top of the truck where i was measuring to make sure they were centered evenly.. i ran ONE power wire from the headlight switch up to the first light.. then to the next and so on .. the ground is done for you when you put the screw in the hole.. and the lights from advance auto come with the rubber grommets.. it comes with all you need for installation bu tthe tape measure and the drill bits and the screwdriver .. and they look sharp when done
Old Sep 9, 2007 | 04:29 PM
rango726's Avatar
rango726
i bought my clearence lights at vip they have model specific lights but i havent installed them because i couldnt find the exact measurments on the spacing for the lights. but you guys are saying that there are markings already there under the headliner?? is that the case.?? that would be awesome but aggrevating too because ive waited so long to install them
Old Sep 9, 2007 | 07:48 PM
dishdude2k's Avatar
dishdude2k
i didnt see any markings per say.. but the way its built theres room for the wires and screws so you can mount them w/o messin up the headliner.. when i measured mine.. there is 5 of them.. take your width of the truck.. (roof only) and then divide that by5 ... from one end measure that distance then again and again 5 times.. if you did it right.. you should have the same result when you get to the end.. i then put my lights up.. and used a led pencil and traced them.. just so i could get the angle down with it so it followed the form of the front of the roof... made sure headliner was out.. and went to drilling.. heres an example
[IMG]local://upfiles/53503/4DDD1A57F88C481F8E96FB03560D4F37.jpg[/IMG]
Sorry im a retard.. divide that by 6 .. comes out to 9 1/3 inches... when measuring you have to count the end of your path as a light even though there is no light there.. in a nutshell.. make sure all the spaces are the same...
