OK, I changed my brake pads What is my next step?
Old Sep 14, 2007 | 09:19 PM
Road Racer's Avatar
Road Racer
Default OK, I changed my brake pads What is my next step?
OK, I changed my brake pads and brakes are still the same? I have to press brake pedal hard to stop.
I tried slamming my brakes on but no wheel lock up? What is my next step???
Old Sep 14, 2007 | 09:46 PM
dishdude2k's Avatar
dishdude2k
Default RE: OK, I changed my brake pads What is my next step?
bleed the brakes
Old Sep 14, 2007 | 09:48 PM
CoastieJack's Avatar
CoastieJack
I don't know a ton about these trucks, but this applies to all others I've played with.
If they're spongy they need to be bled. (That's universal)
If it goes further than normal but still brakes just fine, the pedal needs to be adjusted inward (pistons take too long to engage.) If you push hard and it feels like the pedal stops before it should and doesn't feel like it's using it's full capacity, the pedal is too far back and needs to be adjusted forward.
(I don't know if the pedal is adjustable)
Old Sep 14, 2007 | 10:58 PM
spaz_22's Avatar
spaz_22
could be a bad mastercylinder, and it could also be a bad brake booster. Do you have any assist at all? or does it feel the same as it does when the truck is off...unplug the vacuum line and see if it changes. if it doesn't make sure your getting vacuum to the booster, if you are then change the booster.
spaz_22's Avatar
spaz_22
also check your rears and make sure they are adjusted properly as well
Old Sep 15, 2007 | 06:10 AM
Road Racer's Avatar
Road Racer
When just pads are changed, the brakes do not need bleeding.... Some one posted a while back that it might be the brake booster?
Old Sep 15, 2007 | 02:36 PM
tazman6789's Avatar
tazman6789
but u said the brakes were mooshy befor you did the pads... so it wouldnt hurt to try to bleed all 4 brakes, and if you didnt open the bleeder when u pused the piston back in u crammed old nasty fluid back up the line so bleed that out.
Old Sep 15, 2007 | 02:40 PM
thankuhal's Avatar
thankuhal
If you have bled the brakes, and still have no pedal. I would say you have a bad master cylinder or your brake booster is shot.
[IMG]local://upfiles/71292/2B11F85F8449438B8EDBC715926CFEF7.jpg[/IMG]
Old Sep 16, 2007 | 05:30 PM
bill022572's Avatar
bill022572
I'm still voting for a brake booster (like I did in your post before you changed your pads). It fixed mine. My pedal was hard at the top and would not lock up the brakes - I don't care how hard you pushed.
ORIGINAL: Road Racer
Old Sep 16, 2007 | 10:03 PM
steve05ram360's Avatar
steve05ram360
Read the bottom part of this thread about bedding the brakes... it may solve your problem.
https://dodgeforum.com/m_959389/tm.htm
