How do you fix a steering column bearing?
Old Sep 24, 2007 | 01:33 PM
Eric334's Avatar
Eric334
Default How do you fix a steering column bearing?
Got a small clicking when I come to a stop or take off from a stop. I feel it in the steering wheel. I had a tire shop look at it cause I couldn't find anything in the front end that was worn out or loose. They said it was in the column. I thought I read of a way to fix the bearing that is in the column but I can't find it. Please help if anyone know what I'm talking about.
Oh. sorry, I've got a 2000 Ram 4x4
Old Sep 24, 2007 | 02:20 PM
GlenninTexas's Avatar
GlenninTexas
Default RE: How do you fix a steering column bearing?
This doesn't answer your question directly, but just FYI. I had a C-ring retaining clip break in my steering column, in my 2000 CTD 4x4. Took it to the dealer and they replaced the whole steering column. When it happened, I heard the snap and drove directly to the dealership. Could possibly be the same type issue your having.
Regards, Glenn
Old Sep 24, 2007 | 04:06 PM
DTG07's Avatar
DTG07
I have an 01 4x4 and it has a bad bearing in the column somewhere, it doesnt make any noise when im driving straight or at higher speeds (probly just cant hear over the exhaust), but in a parking lot it clicks like crazy. I took it to my dealership and they told me you have to replace the entire column but it was perfectly safe to drive... replacing the whole column will cost you about $750 at a dealership.
Old Sep 24, 2007 | 05:19 PM
2500 mopar's Avatar
2500 mopar
WORDING
this is so ironic i have done 2 complete threads on this exact problem, because i have it, never got anything good back
THANKS NOW I KNOW WHAT TO REPLACE
Old Sep 24, 2007 | 08:15 PM
2500 mopar's Avatar
2500 mopar
found a whole steering column on summitracing for mine its part number BRG-950, does anyone think this will fix the problem?
Old Sep 25, 2007 | 06:48 AM
HankL's Avatar
HankL
Back in the early years of the 2nd Gen Ram
I remember owners complaining about clicking noise in the steering column
and those still under warranty got dealerships to replace them.
I think the TSB at this listing:
http://dodgeram.info/tsb/group_19.htm
is 19-13-97
I also seem to remember a 'cable tie fix' where owners out of warranty disassembled their intermediate shaft and used a section of cable tie nylon to take up slack and stop the clicking.
This guy:
http://www.rocksolidramtrucksteering.com/
http://tinyurl.com/28mdgy
has advertised on another forum
that he will machine for you a replacement plastic bushing to tighten up the steering.
This Canadian company has a mod for 4x4 Rams that gets good reviews but as a small company they have been known to be slow in filling orders:
http://www.solidsteel.biz/
I also seem to remember that some Ram owners have swapped in a Delphi steering box to replace the Saginaw original and reported that it helped a lot.
Old Sep 25, 2007 | 10:18 AM
aspencop129's Avatar
aspencop129
Here is a lengthy thread from another site with a replacement bushing said to fix the problem....
http://www.dodgetalk.com/forums/showthread.php?t=106366
I believe this is ends up linking to the rocksolidramsteering link that Hank has posted above.
Old Jan 12, 2008 | 05:14 PM
Eric334's Avatar
Eric334
Hey all. I used this product a couple of months ago and I have to say it so far is working great.
It was easy to install and made a big difference in the steering.
I also did the Lukes Link product. Nice item.. But I still have a front end noise that I can't seem to figure out. I just keep changeing out the old stock stuff, maybe I'll find the noice or movement some day.
