I started a new trend with the name thing huh? lol
Anyways, is the T-56 swap hard to do, I want a manual not an auto but I don't want something that is going to take me forever.
Indy, I still think if you'd have taken those laxatives, you'd have broken 15.000.
I noticed your looking into 3.92 gears.Are you looking for just the right balance of off the line plus high end gearing? Are you running 245s right now or are you using thesmaller 225s for racing?what are your RPM's running at the end of the 14 mile? if you have any headroom you might want to consider 4.11s depending on the tire size. Just a thought.
Bouncer88, was that 3" Y pipe your running with the Pacesetters theY pipe from Pacesetter that matches the headers, or was it a custom job?
Quote:
ORIGINAL: aim4squirrels
I have not installed it yet but it is the Y-Pipe that came with the headers I bought.ORIGINAL: aim4squirrels
If you get a new line with the right size fitting for the rear, You can replace the whole rear section without dropping the tank. Mine connects under the front floor board area. That way it is less chance to leak in a hard place to get to. The clip behind the tank is a pain to get loose though.
Quote:
ORIGINAL: Chopper1
yea, im going to redo it and do it that way. i just was in a pinch and had to do it like that though. ORIGINAL: Chopper1
Quote:
ORIGINAL: Bouncer88
the t56 swap hasent been done as far as i know, but the only custom things are going to be; pilot bearing, bellhousing adapter, crossmember, and driveshaft. So, as far as that is concerned its no biggie. The computer may be the biggest issue out of anything. If im going to do a manual swap, i want the t56 for that .5:1 second overdrive gear so i can run something higher than 4.11s, maybe 4.56s, and still get good highway rpms. Aside from the fact that its hard to destroy without making 450ish whp. ORIGINAL: Bouncer88
i have 275/60r17s. Thats the factory size. I was at englishtown raceway today for the swapmeet, and they had a cheep set of american racing wheels in a 5.5x5 bolt pattern that was a 15x10 that i was going to get and put 28" slicks on there, but the guy refused to break the set. As for the fronts....I saw a jeep grand cherokie with a spare, and it got me thinkin...is the grand cher. a 5.5x5 bolt pattern, because if it is, ill just use two of their spares as fronts for the track. As far as my rpms are concerned, its really low, like 4200 or something, because i have to shift into 3rd, and not only do i have to let off the accelerator for it to shift, but it bogs at an indicated 95ish mph(which is really like 85), which kills my trap speed because its like the last 300 ft that it just takes a dump. If you check out my full throttle run with open headers on my photobucket account you can see how it bogs at that speed. Basicly, next season its gears, cam/intake/pcm, posi, and slicks. Im hoping that will bring it down to 14.5s. Either way, Im 100% confident on 14.9s if I can stop that foam from blowing arroundORIGINAL: aim4squirrels
Would it be possible to put the pan and TB on a TB spacerand compact the foam even tighter to try to keep it in place?
Or possibly some sort of collar like on a spring form cooking pan that could set in the tray. What's the dimensions of the pan andthe height of the foam?
Basicly what I need is a section of foam thats 6" tall...mildly hard foam, that I can wrap arround in a horseshoe shape. Once I have that in place I need a metal band to wrap arround the foam that seals the pan, so that it wont go anywhere. The problem is that its not one connected piece, its a 3 piece thing. I have one section siliconed to the hood itself, which doesnt move at all. The other 2 sections are just held on by a lip thats about 1/8th of an inch tall. The big section covers 3/4s of outside of the tray, and the other is the rear 1/4 of the tray, so what happens is that the rear section gets blown out, which in turn takes pressure off of the larger section, and then that just gets blown out real easy. Either I want a larger piece of foam and a band, or I am going to go with some air ducting that fits the throttle body and fits the hole in the hood. The only problem with that is that I havent found one that will clear the bend thats needed, and on the other hand, I dont have the tools to make sheet metal things like that ORIGINAL: aim4squirrels
Im pritty confident that i have atleast another 5 hundreths in it if not another tenth. Im just gonna try again when it gets a little colder. Oct. 9th or 16th is when Im trying again, weather permiting.
indy go to home depot and in the insulation section they have a hard styrofoam insulation in sheets upto 3" thick if u cut it in the shape u want and secure it to ur pan say liquid nail maybe or something along those lines it wouldnt blow around its stiffer and will hold ur air just a mild open idea trying to help .....j
Quote:
ORIGINAL: jusjay727
thanks.ORIGINAL: jusjay727
