smell of antifreeze
Old Sep 29, 2007 | 10:28 PM
bbirch09's Avatar
bbirch09
Default smell of antifreeze
Anyone ever had a problem with a leak in the coolant side of a 5.2L. I am always getting a slight smell of antifreeze from my truck inside and outside of it. Its that sweet smell so im almost positive its antifreeze. I cant see any leaks any where and my level does go down slightly but nothing major.
Old Sep 29, 2007 | 10:34 PM
rabbler's Avatar
rabbler
Default RE: smell of antifreeze
They are common so seep a bit of coolant around the thermostat housing and upper rad hose. look for some black/green goo in that area. Also look where the radiator core meets the plastic end caps for same seepage
Old Sep 29, 2007 | 10:44 PM
aim4squirrels's Avatar
aim4squirrels
I think your heater core is on the way out, that's the only reason I think you'd smell it in the cabin.
Old Sep 30, 2007 | 01:27 AM
motorbrreath's Avatar
motorbrreath
ORIGINAL: aim4squirrels
GREAT! [:@]I just started havin that smell in the cab. also every once in a blue moon when i shut the truck off it dumps antifreeze... i cant find where its comin from but it runs off the back of the engine and down the differential. Damn.
Old Sep 30, 2007 | 08:52 AM
Aircates's Avatar
Aircates
That sounds like what was going on with my truck... My post describes where I found mine leaking...
https://dodgeforum.com/m_987421/tm.htm
And on a little more positive note: Usually when the heatercore starts to leak it will leave a slimy film on the inside of the windshield when you put it on defrost. A down and dirty way to check if it is your heater core is to clamp off both heater hoses and see if your antifreeze stops disappearing.
Old Sep 30, 2007 | 09:08 AM
99Ram1500sport's Avatar
99Ram1500sport
ORIGINAL: motorbrreath
mine did the same thing. dealer said it was the freeze plug
Old Sep 30, 2007 | 10:27 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: rabbler
They are? Where are these plastic end-caps? Sounds more like his radiator core has a leak in it.
Speaking of which -- how do I locate the drain for the radiator core box on the outside?
Old Sep 30, 2007 | 11:18 AM
motorbrreath
ORIGINAL: 99Ram1500sport
freeze plug?
Old Sep 30, 2007 | 11:27 AM
WayneC's Avatar
WayneC
" Speaking of which -- how do I locate the drain for the radiator core box on the outside?"
It's the same as the a/c drain. Below the PCM on the pass. side firewall.
WC
Old Sep 30, 2007 | 11:49 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
GREAT! I just started havin that smell in the cab. also every once in a blue moon when i shut the truck off it dumps antifreeze... i cant find where its comin from but it runs off the back of the engine and down the differential. Damn.
freeze plug?
The correct term is "core plug", but most people refer to them as "freeze plugs".
ORIGINAL: WayneC
WC
Thank, Wayne. I knew they share the same box, I just didn't know where the drain is located.
