squeal under hood
Old Oct 2, 2007 | 08:41 AM
BURNINGVAPORS's Avatar
BURNINGVAPORS
Default squeal under hood
How do you find a squeal under the hood without throwing bunch of new parts?
Old Oct 2, 2007 | 09:30 AM
padodgeram's Avatar
padodgeram
Default RE: squeal under hood
spray wd 40 on the pullys
Old Oct 2, 2007 | 09:46 AM
ONECRAZYJEEP's Avatar
ONECRAZYJEEP
EXACTLY WHERE UNDER THE HOOD IS IT MAKING THE NOISE?
Old Oct 2, 2007 | 10:02 AM
CopperDesigno's Avatar
CopperDesigno
The tensioner and idler pulleys for the 5.9 are like $30 each and teh belt is like another $30, so for a $100 you can swap out everything in like a half hour. I just swapped ou the idler pulley in like 15 minutes and it ended up being the belt, that takes 5 minutes.
If money is tight, then try replacing the belt first. See if the belt has shiny spots on the ribs or cracks, normal wear stuff. If that doesn't help. try to isolate a pulley and replace that first, if it wasn't that one return it and tyr the other pulley.
Good luck.
Old Oct 2, 2007 | 10:05 AM
ONECRAZYJEEP
MY 5.2 SQUEAKED A LOT AND I REPLACED THE BELT AND BELT TENSONER AND NOW IT DOESNT MAKE A NOISE.
Old Oct 2, 2007 | 11:59 AM
BURNINGVAPORS
Well the sound i think now is coming from the ac clutch when it kicks on and off but the tensioner is jumping back and forth 1/4 in. in idle.
Old Oct 2, 2007 | 12:22 PM
ONECRAZYJEEP
it shouldnt be dancing around like that it should keep it tight. if its bouncing back and forth then thats where you slipping is coming from and the squealing. my a/c makes noise too when its on and im just sitting at a light but when i put it in nuetral it goes away. its wierd.
Old Oct 10, 2007 | 09:06 AM
CopperDesigno
It's kind of funny, I have a squeal under the hood now. Its only when I am in Drive, Neutral or Reverse? I replaced the belt tensioner and belt already, that helped for a day. The idler pulley is 2 years old, I plan on picking one of those up tonight.
When the squeal first appeared, it sounded like it came from the front of the motor, but its hard to keep it in drive and poke around under th ehood when its only me.
Any idea of what else it could be, water pump, maybe?
Old Oct 10, 2007 | 09:26 AM
ONECRAZYJEEP
That could be in because if the bearings are bad in the pulley it could give you a squeal. Hope everything works out for you. Oh and my belt tensoner took a crap on me last week. i have to get a new one but its still under warrenty. Less than a year old. Good luck.
