Stalling. Help!!
Old Oct 5, 2007 | 10:13 PM
LPIdaho's Avatar
LPIdaho
Default Stalling. Help!!
1996 Dodge Ram 1500 5.9L
No idea what is going on.
When it starts it revs up like normal but fall back to zero then back up and then falls and then levels out.
Also it seems to have low power all of a sudden.
also after I let off the gas the rpm drop farther and faster than they should
and worst is that some times when costing it stalls and well all know that sucks.
any help/advise???
Old Oct 5, 2007 | 10:40 PM
steve05ram360's Avatar
steve05ram360
Default RE: Stalling. Help!!
welcome to DF...
I'd start with the IAC, probably is sticking and could use a cleaning or just replace it. your best bet is to yank off the TB, clean it up real good, clean the IAC and the area around it (small air bleed hole in there) and go from there. I'd assume you have a good tune on it... cap/rotor/plugs etc...
Old Oct 6, 2007 | 12:59 PM
LPIdaho's Avatar
LPIdaho
Yeah plugs are good, wires only a couple years old. Didn't check the cap, but it isn't runing rough.
Actually discovered the IAC jsut after I posted but havent cleaned or replaced it yet..
thank you.
Old Oct 6, 2007 | 05:43 PM
steve05ram360
let us know what you find...
Old Oct 6, 2007 | 06:15 PM
LPIdaho's Avatar
LPIdaho
well to be honest after thinking about it I have no idea what the IAC is, it just seems like we were talking about the samething.
but, Cleaned the TB up still didn't work right, but a bit better.
Then replaced the throttle position sensor and it seems better.
I guess I'll find out later.
Old Oct 6, 2007 | 06:29 PM
steve05ram360
the IAC is the device mounted to the back side of the throttle body... it has a valve that moves in & out to control the idle. they tend to stick and eventually die over the course of it's life. at the end of the valve is a hole where the valve seats, this area can get gunked up as well as the small air hole I mentioned.
also the manual is linked in the threads at the top (forget which one it is in) so you can download it and use it for reference.
Old Oct 6, 2007 | 08:30 PM
LPIdaho's Avatar
LPIdaho
wow, that's helpfull!
If it's still not right I now know where to look next.
Old Oct 7, 2007 | 07:20 PM
LPIdaho's Avatar
LPIdaho
yep it was absolutly the IAC.
The old one was stuck all the way open.
Thanks Steve05ramn360!
Old Oct 7, 2007 | 07:55 PM
steve05ram360
cool! glad to hear it's fixed...
