odd sounds....?
Old Oct 9, 2007 | 06:30 PM
BadHab1t's Avatar
BadHab1t
Default odd sounds....?
alright guys and gal this ones gonna be hard to explain but ill try my hardest....when im accelerating or should i say when i punch it i hear a ting sound not consistant not to a beat and im not losing power and i only happens when punched to get out around someoneor up to speed has anyone had this happen? or can tell me what it might be it doesnt sound like a rod...yet anyways it might b nothing but if it is i wanna catch it soon.....help.....j
Old Oct 9, 2007 | 08:13 PM
Bouncer88's Avatar
Bouncer88
Default RE: odd sounds....?
Where does it seem to come from? In front of you?Behind you? Under you? My guess would just be a loose exhaust hanger or something and when you accelerate it just moves and hits the nearest piece of metal.
I could be completely wrong but thats my guess with the info you gave us.
Old Oct 9, 2007 | 08:27 PM
BadHab1t's Avatar
BadHab1t
its def coming from motor im pretty sure....j
Old Oct 9, 2007 | 08:28 PM
Bouncer88's Avatar
Bouncer88
I can honestly say I have no idea, sorry man.[&o]
Old Oct 9, 2007 | 08:39 PM
padodgeram's Avatar
padodgeram
pinging...... when you got to much carbon build up in the cycl...run fuel injector cleaner (seafoam)
Old Oct 9, 2007 | 08:42 PM
Bouncer88's Avatar
Bouncer88
ORIGINAL: padodgeram
I was going to say that but he said it doesn't happen all the time and it isn't to a rhythm either.
Old Oct 10, 2007 | 06:21 AM
BadHab1t's Avatar
BadHab1t
ill try that im also gonna try the restore engine stuff....tthanx for the help if anyone else has any ideas im open for them....thanx j
Old Oct 11, 2007 | 12:20 AM
rabbler's Avatar
rabbler
That *restore* stuff won't clean out carbon. Go to the parts store and buy some combustion chamber cleaner/conditioner. and spray it down your intake while the engine is running. It works best if the engine is hot. Let it sit for a few hours then go for a blast down the highway. It's gonna smoke big time out the exhaust when you do this BTW.
You could also have a blown plenum gasket. Lots of posts here on checking it PROPERLY!
Old Oct 11, 2007 | 11:16 AM
92oilburner's Avatar
92oilburner
It very well could be spark knock! You may have got some bad gas. Try a tank full of premium, and see if it still knocks. I agree with the combustion chamber cleaner idea. I also like "Restore" but it will not cure your problem.
Old Oct 11, 2007 | 04:00 PM
Ramafication's Avatar
Ramafication
could be piston slap, sometimes at higher rpm the engine will lose timeing a bit and cause this and it can be inconsistent, either that or your got alifter ready to collapse soon like what mine did, but i got lots of problems in the nature of engine noises lol
