Where do I go from here?
Old Oct 19, 2007 | 06:10 PM
xyzik's Avatar
xyzik
Default Where do I go from here?
Hello all, I just got back from the mechanic because of bad mileage and misfires at 4, 5 and 6 and the diagnosis goes like this:
Compression test: found all cylinders bet. 140 & 150 except #5 had dry test of 75 & wet of 105 (exhaust valve). #4 was dry 80 & wet 125 (rings & valve). also perform leak down test & found 80% leakage @ #4 82% @ #5 cylinder. engine replacement reccomended (145000 miles)
so what the next step for me? thanks
Old Oct 19, 2007 | 06:18 PM
rabbler's Avatar
rabbler
Default RE: Where do I go from here?
Either rebuilt your own engine.
Buy a rebuild
Get a used engine
Sorry dude, that sucks!
Old Oct 19, 2007 | 11:18 PM
spaz_22's Avatar
spaz_22
i see a 408 stroker in your future
Old Oct 20, 2007 | 12:05 AM
rabbler's Avatar
rabbler
I see a bus pass...
Old Oct 20, 2007 | 03:28 AM
xyzik's Avatar
xyzik
the bus pass was the cheapest choice, hehe. the 408 is the most expensive but most tempting. but the rebuilt engine is probably the way to go.
one question is, will i get by with just putting in a new valvetrain assembly?
Old Oct 20, 2007 | 03:46 AM
rabbler's Avatar
rabbler
ORIGINAL: xyzik
You mean rebuilding/replacing the heads on your old engine?
Short answer NO...
If you have a compression loss due to worn/broken piston rings as your test shows.
It ain't gonna help.
Sorry
Old Oct 20, 2007 | 06:14 AM
steve05ram360's Avatar
steve05ram360
I'd recommend a wrecking yard motor with good compression all around. I've gone this way many times with different cars and it's always worked out great. Put the added bux into the next motor to make it solid for years to come... new timing chain, fix plenum etc...
Old Oct 20, 2007 | 11:45 AM
mikerados21's Avatar
mikerados21
Im in the same boat. My motor is jacked up just like yours. But i got easy. I found a motor w/ 66k on it for $500 bux complete. Hope u get out easy like i did.... good luck!
Old Oct 20, 2007 | 12:24 PM
xyzik's Avatar
xyzik
Thanks guys! this forum always rocks! the transmission is another story, hehe...
