transmission part???
Old Oct 21, 2007 | 04:57 PM
suthernoutlaw's Avatar
suthernoutlaw
Default transmission part???
my tranny hasnt been shifting from 1st to 2nd without reving high or letting off the gas. i pulled the pan today and found this part.... any help would be appreciated
http://i33.photobucket.com/albums/d6...noutlaw/t3.jpg
http://i33.photobucket.com/albums/d6...noutlaw/t2.jpg
http://i33.photobucket.com/albums/d6...noutlaw/t1.jpg
Old Oct 21, 2007 | 05:09 PM
bill022572's Avatar
bill022572
Default RE: transmission part???
That's the anchor from the front band. Did you recently do a band adjustment ? If so - it's possible when you were supposed to back off the lock nut on the band adjustment screw you might have mistakenly backed off the band adjustment screw instead. If you did - it could let this part fall out. Pretty sure you would have to pull the valve body to put it back in. If you haven't recently done an adjustment to the band - then I would say you have a major problem with the band which would mean the whole thing would need to come apart.
Old Oct 21, 2007 | 05:58 PM
suthernoutlaw
no i didnt do a band adjustment, the day after i got it back from midas to get it flushed it started acting different, i just no dropped the pan and that was in there
Old Oct 21, 2007 | 06:22 PM
WayneC's Avatar
WayneC
Curious...why did you have Midas flush the trans. Actually, why did you have Midas do anything? Thieves they are (IMO).
Old Oct 21, 2007 | 06:52 PM
suthernoutlaw
short on money, they were the cheapest
Old Oct 21, 2007 | 07:34 PM
dillonjm's Avatar
dillonjm
Well, the only option at this point is to get into the tranny and put that piece back where it goes with the kickdown band. I don't think there is a way to do this with the tranny on the truck.. unless you can squeeze it in the slot via the pan. IIRC the only way to access the front band is to drop the tranny, pull the oil pump from the bellhousing side and the kickdown band is behind that.
Old Oct 21, 2007 | 08:12 PM
rabbler's Avatar
rabbler
You can replace the kickdown strut and anchor without pulling the trans.
You will have to remove the valve body to access though.
If the actual band is damaged you will have to remove and disassemble the trans.
Old Oct 22, 2007 | 12:28 PM
suthernoutlaw
im trying to get the valvebody off, everything is done except i cant figure out how to get the park rod off the valve body.. anyone know how?
Old Oct 22, 2007 | 12:37 PM
rabbler's Avatar
rabbler
There is a C clip that holds the park rod to the valve body. Very awkward to get at.
You can remove the valve body with the park rodattached if you want.
Jack up the rear of the truck and rotate the rear driveshaft while you pull on the park rod.
You will feel the park pawl engage then you should be able to pull the rod out.
It might need a bit of a jerk to get it out.
Good luck
