Body lift is on: (Updated with Pics)
Old Nov 1, 2007 | 02:15 PM
  #51
99Ram1500sport's Avatar
99Ram1500sport
Default RE: Sneak peak: body lift is on, but......
looks great
Old Nov 1, 2007 | 05:00 PM
  #52
Cereal Killer's Avatar
Cereal Killer
Looks real good. Dunno about 500 for the install though. The kit itself is ony like 250 bucks isn't it? At least you have someone to blame if it spits a block out
Old Nov 1, 2007 | 07:49 PM
  #53
padodgeram's Avatar
padodgeram
if that happen the only person you can blame is yourself ... after 100 miles check to make sure bolts are tight...
Old Nov 1, 2007 | 08:16 PM
  #54
Cereal Killer
You did your own didn't you PA? How bad was it?
Old Nov 10, 2007 | 03:38 PM
  #55
Silver_Dodge's Avatar
Silver_Dodge
Well, I finally got a chance to do some work on the truck today to try to fix the vacuum leak I have. That didn't take long though. Turns out, when I replaced the brake booster hose with a longer one, I also replace the PCV hose with a new one because the old one was in poor condition. Apparently while I was attaching that hose to the intake, I accidentally disconnected the other vacuum hose that connects right below it on the intake. That was the problem. Hooked it back up, and my air now works out of all settings again.
The I pulled all my spark plugs and cleaned them up, regapped them, and put them back in. Truck is running a little smoother as a result. Gotta love preventative maintenance.
Old Nov 10, 2007 | 03:58 PM
  #56
05DodgeRamHemi's Avatar
05DodgeRamHemi
Yeah it's good stuff. Nothing beats a good running healthy truck. Really like the lift on your truck by the way, looks nice. I forgot to ask you though, have you felt a differance in performance with the 35" tires? I believe you are like me and have 4.10 gearing with the 35" tires. Did you notice a differance with the bigger tires, does your truck get to speed as good as it did before? I'm only curious because you knew what it was like to have 4.10 gearing with smaller tires.
Old Nov 10, 2007 | 04:15 PM
  #57
Silver_Dodge
Ya, it's sluggish compared to before, but not where I anticipated the sluggishness to be. I thought it wouldn't have any power off the line, but that seems like it has hardly changed. Were I notice it is when I am at highway speed, and I hit a small hill, or I need to accelerate to pass or climb a steep hill. It is kinda gutless compared to what it used to be, and just about any size hill makes it want to kick out of OD now. So it has really affected my final ratio. I think I will reagear at some point but probably not until next year when I will need to tow again. I can get by with this for now through the winter, and that gives me some time to save up for gears.
Old Nov 10, 2007 | 05:09 PM
  #58
05DodgeRamHemi
Yeah off the line power is still incredible for me as well. I noticed it HATES hills and getting up to highway speeds like you said. What did you mean that is kicks out of OD? Does it say O/D off? I haven't experienced anything like that before where it will kick out of OD, it just kind of hops around the rpm gauge when I go up hills, almost like its confused. Is that what you meant, or does the O/D off light actually come on your gauge cluster?
Old Nov 10, 2007 | 05:23 PM
  #59
Cereal Killer
I think he just means the truck always downshifts into third gear. I've never actually heard off anyones "O/D off" light coming on without pushing the button.
Old Nov 10, 2007 | 05:31 PM
  #60
Silver_Dodge
Ya, I just mean it downshifts out of overdrive gear into 3rd gear. The light only comes on if I hit the button.
