NED INFO/HELP RE.BAND ADJUSTMENT ON TRANSMISSION
Old Oct 25, 2007 | 04:12 PM
mcss8541's Avatar
mcss8541
Default NED INFO/HELP RE.BAND ADJUSTMENT ON TRANSMISSION
I HAVE A 1998 RAM1500 SPORT 4X4 WITH AUTO TRANSMISSION. I'VE READ WHERE YOU ARE SUPPOSED TO DO SOME KIND OF BAND ADJUSTMENT WHENEVER YOU CHANGE THE FLUID AND FILTER. I PERFORMED THIS PROCEDURE THIS PAST WEEKEND HOWEVER; NOT KNOWING WHAT TO ADJUST AND THE FACT THAT THE TRANSMISSION WAS REBUILT BY THE DEALERSHIP CLOSE TO A YR AGO, I DID NOT DO A BAND ADJUSTMENT. FOR FUTURE REFERENCES IS THIS SOMETHING THAT IS DONE BY THE OWNER OR IS IT AN AUTHORIZED DEALER PROCEDURE ONLY? SECONDLY IF IT'S SOMETHING THAT I CAN DO AT HOME HOW FAR INTO THE TRANNY DO I HAVE TO GO OR IS IT A BOLT/SCREW THAT'S NEAR THE FILTER? AND LASTLY HOW SNUG DOES IT HAVE TO BE. WHY DOES DODGE TRANNY'S REQUIRE A BAND ADJUTMENT BUT FORD AND GM TRANNY'S DO NOT? WELL THANKS FOR THE HELP.
Old Oct 25, 2007 | 04:39 PM
ICEMAN_CH's Avatar
ICEMAN_CH
Default RE: NED INFO/HELP RE.BAND ADJUSTMENT ON TRANSMISSION
http://www.dodgeram.org/tech/transmi...T_band_adj.htm
Here is a link explaing how to do it. By the STOP USING CAPSS!!!!!!!!!!!!!!!!!!!
Old Oct 25, 2007 | 04:55 PM
ICEMAN_CH's Avatar
ICEMAN_CH
http://www.geocities.com/wnyaspen/transtech2.htm
Here is another way to do it.Again TURN OFF YOUR CAPSSS!!!!!!!!
Old Oct 25, 2007 | 05:09 PM
mcss8541's Avatar
mcss8541
THANKS FOR THE INFO. I LIKE CAPS AND I APOLOGIZE IF THEY OFFEND YOU HOWEVER THIS IS THE PREFERENCE IN WHICH I TYPE. I DO NOT LECTURE YOU ON YOUR MISSPELLED WORDS.........
Old Oct 25, 2007 | 05:19 PM
ICEMAN_CH's Avatar
ICEMAN_CH
It's okay. I'm mostly giving you a hard time.Don't worry about it.It is semi rude to type in caps and most of my misspelling is becauseI'm metally handicap and thanks for pointing it out. NowI'm going to go cry in a corner.
Old Oct 25, 2007 | 05:46 PM
mcss8541's Avatar
mcss8541
Hey that makes two of us....well since you met me half way and you DID help me out I guess I can accomodate you.
Old Oct 25, 2007 | 06:01 PM
ICEMAN_CH's Avatar
ICEMAN_CH
ROFL
Thanks man, your awesome.
[sm=bounceybounce.gif]
Old Oct 25, 2007 | 06:58 PM
Sirhilton17's Avatar
Sirhilton17
"WHY DOES DODGE TRANNY'S REQUIRE A BAND ADJUTMENT BUT FORD AND GM TRANNY'S DO NOT?"
Since when do ford and gm trannys not require band adjustments?
Old Jul 16, 2009 | 02:10 AM
iitywygms's Avatar
iitywygms
Raising a dead thread I know. I have a simple question, should the tranny be in park or neutral or what during the adjustment? Or does it matter?
Old Jul 16, 2009 | 03:23 AM
04 neon's Avatar
04 neon
Since at least the introduction of the th350/ 400 trannies for GM and the C4/ C6 (i'm fairly sure) for Ford
