New Ram, New Problems, PLEASE HELP!
I picked up a 98 Dodge Ram 1500 4x4 today, Having a couple problems with it, hopefully someone can help me with. Appreciate it folks!
#1 (biggest problem)The truck jerks/hesitates/shutters(kind of feels like a misfire)when under 2k rpm, above 2k rpm it feels like its brand new from the factory, the problem is also less apparent when o/d is off. I dont think its a sparkplug/wires/coil problem because its only under 2krpm
#2 The check engine light flashes at me, but when I connect my scan tool I dont get a connection, the scanner does not even try to connect, the obd2 port isnt delivering power to the tool.
#3 the brakes "shutter" when I slow down
#4 Gear selector is very sloppy and doesnt correspond w/ PRND12, I have to count up and down when shifting
Pin 16 (bottom right on the DLC connector) is a 12 v power for the scantool/code reader.
Check the cigar lighter fuse.
Check the state of the tune up. Plugs, cap, rotor., etc. How many miles on this bad boy?
A compression test and a fuel injector flush might be a good place to start too.
thanks for all the replies guys,
well first off I think I may have figured out my major problem, a bad plenum gasket would cause the truck to misfire, correct? I did some research, went outside, let the truck warm up and idle, held my hand over the open oil fill cap and it was like a vacuum cleaner, which is a very bad plenum gasket. I went ahead and ordered a new kit from hughesengines.
and about the DLC, you said it was same circuit as the interior lights, well my dome light is on a switch for some reason, so the lights dont turn on when I open the door, I have to turn em on manually w/ a switch, can anyone link me to a wiring diagram?
and there is 130k miles on the truck
thanks again!
thanks again!
also there is alot of controversy on spark plugs, which ones do you recommend
Trending Topics
700 bucks!!! Well, I guess you can drive it like you almost stole it! Congratulations!Since you'll be doing the plenum repair, you'll have easier access to the distributor, rotor, wires, TB, sensors, etc. Now is the time to check everything that the good access gives you. Cleaning the TB is a good idea,the sealing surface for the IAC plunger on mine had lots of crud and so did the plunger. That may help you a little bit withidle and just off idle. You're working on getting your codes read, and that's a great first step before you tear it down.
Brake shudder is common, usually it's due to warped rotors. You can have your rotors turned or get some new killer drilled and slotted rotors on eBay for cheap money, such as: http://cgi.ebay.com/ebaymotors/Dodge...QQcmdZViewItem
This site has FAQ's and DIY's, including one for the plenum repair, and they're very helpful. Also check:http://www.v8performance.com/tipsandtricks.htm Good luck!
