what size lift?
Old Nov 9, 2007 | 02:11 PM
radio flyer's Avatar
radio flyer
Default what size lift?
snapped a couple of pics. its a 96 2500 . its a little lower in the back(soon to be changed), but im guessing 4-3, maybe 5-4. it clears the 35ats no sweat if this helps
http://img144.imageshack.us/my.php?image=1001321dc1.jpg
http://img204.imageshack.us/my.php?image=1001322eb4.jpg
http://img134.imageshack.us/my.php?image=1001323zo6.jpg
http://img118.imageshack.us/my.php?image=1001324nz8.jpg
http://img118.imageshack.us/my.php?image=1001325lu4.jpg
http://img87.imageshack.us/my.php?image=1001326cw2.jpg
Old Nov 9, 2007 | 02:15 PM
padodgeram's Avatar
padodgeram
Default RE: what size lift?
u got a 5" with a skyjacker susp , skyjacker trac bar.
Old Nov 9, 2007 | 03:02 PM
radio flyer
im new to dodges. that any good? it rides ok.do i have a trac-bar problem to worry about in the future? also , are those the stock blocks? im guessing it has a AAL for rear lift
Old Nov 9, 2007 | 03:25 PM
zique's Avatar
zique
It looks like all your tie-rods were swapped out as well, but I can't guarantee that since I'm not a 2500 owner. You do have an AAL in the rear. Stock Dodge springs are the 3 springs (4 if you count the overload).
Old Nov 9, 2007 | 05:06 PM
radio flyer
anybody else?
Old Nov 9, 2007 | 05:12 PM
padodgeram's Avatar
padodgeram
Its better to give us numbers with the lift (bumper to ground) front and rear.. more than likely since its a skyjaker up front thats a AAL was added in the rear the stock block in the rear is 3"
Old Nov 9, 2007 | 05:17 PM
radio flyer
thanks for th replies
are 5" blocks to big to go on these trucks?
Old Nov 9, 2007 | 05:26 PM
Silver_Dodge's Avatar
Silver_Dodge
Some of the guys over on PS have said that a 5" block gave them axle wrap. If you get a zero rate to go with it, you can correct that, but that is still a lot of block, and you might have to stack them to do it that way (not a good idea in most people opinions). I think an AAL is the best way to go personally.
Old Nov 9, 2007 | 05:27 PM
Cereal Killer's Avatar
Cereal Killer
They make 5 " lift blocks for Rams, they're fairly new. I suppose they're safe if they're on the market, but I think they look ghey...
Old Nov 9, 2007 | 05:35 PM
radio flyer
im trying to level the truck so i would be leaving the AALs in, that should take care of the axle wrap right. on the 2500s the packs are more rigid anyway
