how much lift clears 35's
Old Jan 4, 2015 | 04:35 PM
  #31
BigGreenRam's Avatar
BigGreenRam
Default lift and tires
My plan is 3 inch lift rough country longer coils not a spacer comes with all four control arms drop down brackets for sway bar rear 2.5 blocks 4 shocks and an adjustable track bar just for the extra built in adjustment for alignment now
Tires 305x70x16 a 33 12.5 well real close little over little under and a 16x8 wheel
with a 4.5 backspace should look great and run without any rubbing at all if I'm wrong let me know before I drop 3 grand lol thanks :icon_headbang
Old Jan 4, 2015 | 06:14 PM
  #32
Johnn123's Avatar
Johnn123
Youve got a good set-up there! Try ordering parts individually, should cost you a lot less. Get 3" lift coils, lower c-arms if youre worried about them, adustable track bar, longer front shocks and rear 2" long add-a-leafs and you'll be set. I wouldnt worry about the sway bar links, order drops if ya like.
Old Jan 4, 2015 | 07:33 PM
  #33
BigGreenRam
Thanks been doing a lot of research and looking at lots of lifts the rough country lift comes with every thing I need to do the 3 inch lift and with the 305 tires the stock gear will work I'm running 265x75.16 goodyear rts there 32.4 I think so not going much taller just wider
thanks for replying
Old Jan 4, 2015 | 11:35 PM
  #34
Johnn123's Avatar
Johnn123
thanks for replying
For what it you get for the price, its a good kit Ill give it that. You may find once you got 33x12.5 you'll want more gear then 3.55. I quite enjoyed my 285's with 4.10's.
Old Jan 5, 2015 | 07:03 AM
  #35
BigGreenRam
Yeah now the 285 is around a 35 I think if I was going that big sure new gears from what I have now it will be only 1/2 or 3/4 taller not enough tire to spend the money if I need it sure
ill change them with a new locker
Old Jan 5, 2015 | 07:47 AM
  #36
I hope the wheels and tires are included in that three grand.......
Old Jan 5, 2015 | 08:05 AM
  #37
BigGreenRam
Yes they do morning that's my budget should not be that much but I'm sure it will be real close to it lol
Old Jan 5, 2015 | 09:10 AM
  #38
Johnn123's Avatar
Johnn123
285/75/16 generally equates to 33x11. Sounds like a good plan ya got there.
Old Jan 6, 2015 | 05:22 PM
  #39
JRedRam's Avatar
JRedRam
I'm running 35's on an 01 1500 2WD with just a 2.5" coil spacer.
Which brings me to my real question. I was just about to buy 3" lift coils, and was told I would also need to buy the control arms if I want to go any higher than a 2" level lift in the front. Is this true?
Old Jan 6, 2015 | 06:49 PM
  #40
Johnn123's Avatar
Johnn123
Thats if youre a 4wd. With your 2wd IFS, 2" is about all you wanna do suspension wise. IMO. I am unaware of any 3" lift coils for a 2wd.
A 3" body lift is a much better option for you being a 2wd.
