Electric cooling fans
Old Nov 16, 2007 | 09:32 AM
stroken76's Avatar
stroken76
Default Electric cooling fans
I have a 99 ram 5.9 (gas) wondering if anyone has any info on electric cooling fans, If you have installed one or know where to pick one up that will fit the truck without building a schroud for them Thanks.
Old Nov 16, 2007 | 12:08 PM
HankL's Avatar
HankL
Default RE: Electric cooling fans
A search on terms like "Viper Fan" and "Lincoln Mk" or "Taurus fan"
will turn up many many posts with info.
Here's a good weblink with more reliable info than most:
http://www.geocities.com/smithmonte/...rkVIII_Fan.htm
Don't forget to make sure your alternator is up to the task.
The GM HRR fan is relatively cheap brand new and has gotten good reviews.
3% gain is about the ballpark for the MPG improvement at highway speed so don't expect miracles.
Old Nov 16, 2007 | 08:39 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Well, I can't tell you off hand which fan will be best for your application, but I recently did a write-up on fan installation in the tech forum that might help you with some of the other details.
https://dodgeforum.com/m_1041851/tm.htm
Old Nov 18, 2007 | 12:48 AM
ryans590's Avatar
ryans590
look here https://dodgeforum.com/m_451029/tm.htm
i know shott8283 is running eletric fans
Old Nov 18, 2007 | 09:28 PM
aim4squirrels's Avatar
aim4squirrels
Flex-a-lite makes the best aftermarket fan setupsIMO. They're very simple to install andcome with pretty good instructions. They also don't pull huge amps like some of thefansthat were made for other vehicles.
I not saying that the Lincoln, Viper, Ford Winstar, GMC, and others aren't good, they're just not as plug and play as the flex-a-lite setups.
Old Nov 18, 2007 | 10:41 PM
ryans590's Avatar
ryans590
aim4squirrelsdid u ever do the electric fan modIIRC you were looking into it a while ago
Old Nov 19, 2007 | 07:49 AM
Bouncer88's Avatar
Bouncer88
ORIGINAL: aim4squirrels
Agreed, I am going to be ordering the setup RM-Indy has this winter hopefully I guess they actually do make quite a difference when looking for speed, plus it is cool that they go on only when the engine gets to a certain temperature, meaning they don't run all the time.
Old Nov 19, 2007 | 07:58 AM
aim4squirrels
ORIGINAL: ryans590
Yup, running them now. 16" puller 14" pusher with the flex-a-lite controller.
