lost gas mileage
Old Nov 18, 2007 | 07:32 PM
Williamspring's Avatar
Williamspring
Default lost gas mileage
on my 99 dodge 1/2 2wd 318 ram i used to get about 330 miles a tank till the gas light comes on truck has 400,000 miles on it the 5 cylinder misses sometimes narrowed it to the point of dirty injector and it has done that since about 100k miles has new oxy sensors got put in about 50k miles ago i dont know what is causing it any know what could cause it?
Old Nov 18, 2007 | 09:17 PM
XXL 1500's Avatar
XXL 1500
Default RE: lost gas mileage
have you done full tune up?
plugs, wires, cap, rotor, replaced the bad injector?????
your running on 7 cylinders... they have to work harder to compensate...
= bad MPG
how is the plenum in the truck?
plugged exhaust system can cause a Seriously BAD MPG issue
Old Nov 18, 2007 | 09:18 PM
XXL 1500's Avatar
XXL 1500
Oh and
Welcome to DODGE FORUM!!!!!!!
Old Nov 18, 2007 | 09:31 PM
ICEMAN_CH's Avatar
ICEMAN_CH
400K wow thats amazing.
Old Nov 18, 2007 | 09:36 PM
XXL 1500's Avatar
XXL 1500
ORIGINAL: ICEMAN_CH
that is like biblical
Old Nov 18, 2007 | 10:16 PM
CoastieJack's Avatar
CoastieJack
ORIGINAL: XXL 1500
ORIGINAL: ICEMAN_CH
Like Al Bundy taking his Dodge to 1,000,000 miles!
Old Nov 18, 2007 | 10:23 PM
Williamspring
well it had a full tune up about 15k ago and thecylinder only misses in city drving and every once in a while at that but the in and its only running about a 5% more fuel when i checked it with snap-on scanner and ya its a dodge will last forever
Old Nov 18, 2007 | 10:26 PM
Williamspring
o ya forgot this info it went from 330 till light to 230havent changed tires or anything to make odometer go off
Old Nov 19, 2007 | 06:11 AM
HankL's Avatar
HankL
Did you change the oxygen sensors
before or after
the miles per tank change happened?
Did you use NTK oxygen sensors (what Chrysler used most years)
or did you use Bosch (what most auto parts stores carry) ?
Some Ram owners have reported problems with Bosch O2 sensors.
If you suspect the injector in #5
I personally would have swapped it over to its 'sister' cylinder #6
and see if the miss goes to #6 too.
At 400,000 miles it is not a bad idea to pull all the fuel injectors and inspect the little screens at the top designed to catch stuff big enough to foul the injector pintle. Have new o-rings on hand to reassemble.
At 400,000 miles
is your torque converter lockup clutch still working right
or do you have a manual trans?
My TCC failed at 180,000 miles.
Have you changed tires recently,
added a high camper top,
or put on a heavy tool box?
Old Nov 19, 2007 | 07:21 AM
steve05ram360's Avatar
steve05ram360
welcome to DF...
have you checked compression lately on the motor? could be at the end of it's life... 400k is alot for a gasser IMO.
